Home > Maintenance & Mods (L322) > F*****g thing won't start!!
Nappler
2003 Range Rover Vogue 4.4 V8 Java Black
I was out in my car tonight, went to Sainsburys, got some shopping, all fine and normal, get back in started it, it fired up then immediately cut out, tried to start again, the headlights came on while turning key, no attempt to crank, I got the Air Suspension inactive thing come up too, the car looks like it has power, Nav still comes on, steering coloumn moves etc, as soon as I try and crank it, I get the headlights coming on for a few seconds while trying and nothing.
Does anyone have any ideas?, I called the AA but there was a 2 Hour wait and I was only a few Miles from my house so I got a lift home and will deal with it tomorrow.
Post #233502 7th Jan 2014 11:28pm
JAYBOY
Disconnect the battery reset the car. Question
Whats your battery like Question 2020 Porsche Panamera Turbo Hybrid (V FAST)
2018 JCW Mini Cooper
2018 Skoda VRS
Post #233507 7th Jan 2014 11:41pm
Nappler
I will give that a try tomorrow, Battery is ok I think, although sometimes I get HDC inactive on first start in the mornings so maybe it's on its way out.
Post #233515 8th Jan 2014 12:35am
Battery goosed.
Post #233519 8th Jan 2014 8:24am
E4 GUY
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
I think you're right . HDC message is what mine did regularly.
For sake of £98 for the uprated varta one was a no brainer.
Not seen message since Thumbs Up Alcohol and eBay is never a good mix
2006 4.2 Supercharged, Java Black
Post #233520 8th Jan 2014 8:24am
Nappler
What's the best course of action?, call AA booster pack, the put a new battery in?, it's doing some very odd things electrically so would assume it cold be the battery actually knowing what FFRRS are like!!.
Post #233529 8th Jan 2014 10:09am
Best option would be to change it Thumbs Up
Post #233530 8th Jan 2014 10:18am
...and dont forget to do the steering lock fully left and then fully right ...how to in the wiki..
Post #233533 8th Jan 2014 10:24am
Nappler
No worries Stan, I learned that trick well from my previous FFRR Thumbs Up .
What is the best battery to put in, just got a quote on a Bosch one £140.
Post #233542 8th Jan 2014 11:48am
bosch/varta 020, 110amph, 920cca is the best..
Post #233543 8th Jan 2014 11:50am
Nappler
Well it turns out it was a bad connection to the Earth on the Battery, battery is fine, car is running fine now, quite a relief, I might still get a new battery although mine is only from 2012 apparently so I will wait and see if I get another HDC inactive in the morning first.
Post #233559 8th Jan 2014 1:29pm
how did you find that it had a loose connection ?..
Post #233562 8th Jan 2014 1:43pm
Nappler
AA man was wondering why it wasn't cranking even with booster power so ran a tester on it, turns out the Negative terminal had some play but it looked like it was fully done up, un did it and re connected it properly and all seems well, the car cranked really well from cold under its own steam without any booster.
I will be keeping an eye on it though, first sign of an HDC inactive message in the morning and I'm getting another battery.
Only bad point is the CD Nav now keeps spitting the disc out, something of a common electrical gremlin so I gather?.
Post #233650 8th Jan 2014 10:09pm
JAYBOY
Disconnect the battery again and do a reset Thumbs Up Smile 2020 Porsche Panamera Turbo Hybrid (V FAST)
2018 Skoda VRS
Post #233662 8th Jan 2014 10:39pm
goldsax
United Kingdom 2011 Range Rover Vogue 4.4 V8 Ipanema Sand
hi Nappler,
what MY is the car?
as quite a few 2007 have been known to have alternator failures. that then corrupt the battery 2011 4.4 TdV8 Nara Bronze
Post #233674 8th Jan 2014 11:11pm
