I have the OEM rubber mat set. The driver’s mat does not go under the pedals, as it used to on the L322, but it doesn’t need to. It’s oblong and sits neatly in the floor area over the rubber wear pad, and comes to the top of the little ramp – i.e. stops level with the bottom of the rubber left foot rest. It replaces the carpet mat which is there on delivery, and hooks on using the same rubber toggle things on the floor. I recommend it – collects a lot of dirt and saves the carpet from heel wear, and I don’t see the uncovered area getting significant wear and tear. I think a lot of manufacturers stopped putting mats under the pedals because of problems with them riding up and interfering with the pedals – may even be a legal requirement in some countries.
I guess you could easily put down something like the clear plastic sticky backed stuff (the removable sort which decorators use) on the uncovered part under the pedals if you wanted to protect the carpet there. Norman
Current LR: L405 Vogue TDV6 (MY 2014) Aintree Green/ Ivory interior
Past LR: L322 Vogue 4.4 V8 (2002); Discovery series1 V8 (1995)
