Home > Technical (L322) > BP V TESCO Diesel
Page 4 of 6 <123456>
"I can safely say it matters not where I fill up, it's just my driving style/tyres that affect my MPG."
^+1 Thumbs Up
Post #233346 7th Jan 2014 11:04am
stan wrote:
unless you have documented proof i really cant see how you can claim that supermarkets supply 'near to sell by date' fuel and thats why its not as good as branded fuel...i would have thought that a small shell/bp etc garage in a village somewhere would have older fuel in its tanks because of a small customer base whereas supermarkets have a very large turnover so you always get fresh fuel.
all fuel must be supplied to british standards and is the same from branded suppliers and from supermarkets, the only difference is the additives and the fact that supermarkets sell at a smaller profit to entice you to their stores...branded suppliers charge more for their fuel and additives because of their convenient locations and that there will always be someone that buys from m&s rather than asda attitude..
if anyone thinks that theirs makes a difference then buy from them and line their already fat pockets...
for the majority of consumers , paying less for fuel does make a difference to the economics of running a car but if you can afford it and you think branded fuel is better then buy from the branded suppliers..
Stan I did not "claim" anything. I said "I guess" - I have only read/heard rumours that Supermarkets but the cheapest available which I suppose could be bottom of tank or nearly out of date who really knows. My actual point remains that the Premium suppliers use more additives than the supermarkets. Thumbs Up
Post #233349 7th Jan 2014 11:13am
GraemeC
United Kingdom 2007 Range Rover Vogue SE TDV8 Zermatt Silver
I don't know about fuel processing etc. so will only comment on my personal experience....
In my old Fiat Coupe (petrol 20 valve turbo) I could feel the difference when using branded fuel compared to supermarket fuel.
Indeed, some branded fuel seemed better than others and I ended up always using Shell V Power.
When I sold the car it had done 120k miles and the engine pulled as strongly as it did when I purchased the vehicle at 20k miles.
In the RR (diesel) the difference is much less marked, however it seems to run smoother on branded fuel, start a bit easier and get 1-2mpg more.
However, I fill up when its convenient so probably run about 50:50 branded/supermarket and have never had any issues.
I also ran a can of BG244 through the system and believe that helped (thanks Gaz Thumbs Up ) 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #233359 7th Jan 2014 12:13pm
pld118
I'm not buying your car as you've used supermarket fuel!
I've no clue as to whether Vpower Nitro+ is better than supermarket super unleaded or unleaded. I just use Vpower because, psychologically at least, it makes me feel I'm doing the best I can to feed it properly and for the sake of a difference in about £8 odd every week or two, it doesn't seem too big a deal, particularly "if" there is a long term benefit.
Does it perform better/ give better fuel economy? Fuel consumption no. Performance maybe a bit smoother but that could be me trying to convince myself!
Here's one:
Would you ask someone selling you a Range Rover whether they have run it on supermarket or branded fuel and if the answer was supermarket fuel, would you then not buy the car Question
Post #233366 7th Jan 2014 12:50pm
73vse
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
if we are talking petrol rather than diesel ..... then us owners of classic cars need to be more careful over which fuel to use as these days standard unleaded & some super has very high content level of ethanol which can damage older rubber seals, fuel lines etc
I try & use Shell V-Power nitro unleaded in my classic cars as I know it has 5% or less ethanol content
I think Tesco 99 has quite high ethanol content ???
Post #233388 7th Jan 2014 1:26pm
Just filled up at my very cheap local SHELL garage.... Whistle
Post #233392 7th Jan 2014 1:40pm
TugRR
Always an emotive subject, this one . . . !
I'm stuck where I live with little choice of fuels & brands.
However, if I did have more choice, I'd put Shell in my fleet.
I have a relative who was a fuel scientist for Shell (now retired). After some pretty lengthy conversations with him, I'm convinced as to the additional lengths that his company went to prove the efficiency and safety of their additives. For example, they ran a fleet of varied vehicles through normal Joe Public usage using different fuels they had created. At prescribed intervals, the engine would be taken out and stripped before being examined by them and the manufacturer.
As I understand it, the real benefits come with prolonged use of these fuels - the odd tank now and then won't necessarily help.
I put £90 of Shell V Power not long ago in mine as I was passing a Shell garage. Why did I do it ? - so I could get the Ferrari Lego that came with it ! Laughing
Thumbs Up Where do you go after one of these . . . ?
Post #233395 7th Jan 2014 1:54pm
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
My Tesco Express down the road is a BP .. so er .... Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #233411 7th Jan 2014 2:44pm
Ifs it a BP with just a Tesco Shop your getting Premium BP.
Post #233413 7th Jan 2014 2:50pm
i fill up at my local asda with smartprice petrol, its like regular premium petrol but cheaper .....
Post #233421 7th Jan 2014 2:59pm
Shell Optimax...the only petrol not subject to swap agreements as it is so good. Wink
Shell V-Power Nitro+ Diesel is our best performance diesel fuel, designed to actively clean your engine.
Cleaner engines perform better, which is why we created Shell V-Power Nitro+ Diesel with its unique double action formulation.
It’s specially formulated for increased cleanliness and protection of diesel fuel injection systems.*
It contains anti-rust components designed to prevent corrosion of precision-engineered fuel injection systems.
Designed to act the moment it hits your engine to restore and maintain engine power through active protection.
Shell V-Power represents more than 100 years of commitment to the production of high quality fuels. To meet the evolving needs of drivers and their cars, 120 fuels scientists and specialists across the globe work on fuels innovation, development and product implementation. Shell V-Power Nitro+ Unleaded has been developed through their passion for performance.
Shell scientist with petrol pump
Cleaner Fuel Injectors
Shell V-Power Nitro+ Diesel contains a new, more powerful detergent technology for faster and more effective clean up of diesel fuel injection systems*.
Deposits on the diesel injectors can impair the fuel spray and reduce the fuel flow - resulting in power loss.
Shell V-Power Nitro+ Diesel is specially formulated for increased cleanliness and protection of diesel fuel injection systems in the latest diesel engines.*
http://www.shell.co.uk/gbr/products-servic...iesel.html
Post #233424 7th Jan 2014 3:06pm
DMRR
Why does it have to cost 10p a litre more though? Makes ZERO sense. Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #233430 7th Jan 2014 4:16pm
DMRR
Yet it's the cheapest near me and a supermarket. So in fact, there is no argument? Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #233431 7th Jan 2014 4:16pm
^ Exactly. Its large Supermarket Branded Fuel that I believe has less additives but that my opinion of course.
Post #233438 7th Jan 2014 5:07pm
wealy
Spoke with my mate who has a 57 plate TDV8 that has 197,000 miles on it. He said he nearly always fills up at our local morrisons, has never put any cleaner through it as he has not heard of them and also would not go out of his way anyway to put shell in?
I have also spoken to another mate who has a 58 plate passat which is a taxi and is coming up to 375,000 miles now, and again he has only ever put cheap fuel through it - mostly morrisons due to the points. He has only ever had pads discs and tyres and is still only on the second clutch. He put cleaner through it once about a year ago, but didn't think it was worth it, so its not had any since.
Make what you like of all that!
Post #233449 7th Jan 2014 6:00pm
