Home > LPG > LPG grief
Tallsaj
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
Thanks mate will call him on Monday. I have a BRC system on mine with 2 vapourises. Also how can any one explain why its doing it on petrol as well as LPG ?
Post #232903 4th Jan 2014 9:40pm
ironhorse
United Kingdom 2003 Range Rover Vogue 4.4 V8 Giverny Green
he has done a lot of work on those systems and fitted them in the past so well worth giving him a go
Post #232910 4th Jan 2014 10:34pm
Tallsaj
Ok thanks I take it you know him well?
Post #232911 4th Jan 2014 10:51pm
ironhorse
probably known him for 15 years now had a number of BRC kits off him in the past for DIY fitment on my past ranges and discos
he fitted the prins on my ff and very pleased with work done , i dont recommend many people but he is one i would
Post #232916 4th Jan 2014 11:46pm
Tallsaj
Ok thanks. I just he can suss my problem out. Can I mention ur name? Also is ur range SC?
Post #232918 5th Jan 2014 12:01am
I can recommend a very good guy off Jn 13 of the M5... 60 or 70 miles south of you... Rob Gallop @ Autogas Logistics 01453 825932 Thumbs Up
Post #232973 5th Jan 2014 11:43am
CG-SC
2006 Range Rover Autobiography Supercharged Zambezi Silver
Could be a MAP sensor related fault. Also, does your LPG conversion have an OBD2 connection for the LPG ECU to monitor and adjust the mixture ? Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather.....
Post #232997 5th Jan 2014 12:53pm
Tallsaj
Hi mine is abrc system not sure if it has a obd to adjust the mixture
Post #233042 5th Jan 2014 3:48pm
Tallsaj
CG what system U got fitted to your sc?
Post #233053 5th Jan 2014 4:34pm
klf400
make sure the air intake pipe to the engine is not come adrift or not tightened up properly ,allthough mine is the bmw m62 and not the jag sc but had the same fault on mine the eml would come on but the car drove fine the intake pipe was not on properly and was taking in air after the air filter and maf sensor which made the eml light come on
so refited the pipe retightened it and its been fine ever since Thumbs Up 1990 3.5 v8 defender
2000 4.6 v8 30th anniversary prins lpg
2004 4.4 v8 vogue prins lpg
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #233060 5th Jan 2014 5:09pm
CG-SC
I've got an EMER system fitted, runs fine........ Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather.....
Post #233107 5th Jan 2014 7:32pm
