Home > Technical (L322) > Steering Wheel Ghost
E4 GUY
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Had a few strange going on's with steering wheel height ?!
Very occasionally it adjusts itself down, to the point I can't get my legs in!
Adjustment stalk unresponsive.
If I turn car off and on, sometimes more than once , it resets and I can adjust
Anyone else had this ? Alcohol and eBay is never a good mix
2006 4.2 Supercharged, Java Black
Post #232832 4th Jan 2014 4:35pm
Googsy
Only when I use different key I assume you are using same key? Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #232833 4th Jan 2014 4:45pm
Re: Steering Wheel Ghost
DON'T let it do it! Otherwise it will eventually get to the bottom and self destruct... Do you have an iid tool? If so, turn off the auto axial function therefore it won't set everytime you put your keys in or out... Thumbs Up
Post #232841 4th Jan 2014 5:09pm
paul271
Scotland 2002 Range Rover Vogue Td6 Epsom Green
Craig can this be disabled using Autologic?
Post #232893 4th Jan 2014 8:50pm
Yes i think it can Paul... Axial & Radial motors should be what your looking for sir Bow down
Post #232968 5th Jan 2014 11:16am
paul271
Bow down As always thank you very much Yoda!!! Very Happy
Post #233072 5th Jan 2014 5:46pm
Post #233093 5th Jan 2014 6:50pm
