Home > Technical (L322) > wing mirrors gone mad
andyleeds
United Kingdom 2005 Range Rover Vogue Td6 Zambezi Silver
i had my wing mirrors tucked in last night and this morning one was stuck out..... now when i press the button when one goes out, the other comes in so they are out of sync.... any ideas of how to correct this? i have tried moving one of them manually so they are both starting from the same position but this doesnt work and they revert to what was happening before....
andy
Post #232253 1st Jan 2014 12:32pm
a quick double press of the door mirror fold button normally works [might need to be done a few times ] or a battery disconnection..
Post #232257 1st Jan 2014 1:10pm
NormanP
United Kingdom 2014 Range Rover Vogue TDV6 Aintree Green
As Stan says, might need to do the button press a few times. More here:
http://www.rangerovers.net/forum/6-range-r...synch.html Norman
Current LR: L405 Vogue TDV6 (MY 2014) Aintree Green/ Ivory interior
Past LR: L322 Vogue 4.4 V8 (2002); Discovery series1 V8 (1995)
Post #232259 1st Jan 2014 1:43pm
redshovel
United Kingdom 2010 Range Rover Autobiography Black TDV8 Barolo Black
This happened to my ff once. Only solution was a battery disconnect for 10 mins. Went back to normal and never happened since!
Post #232262 1st Jan 2014 2:05pm
MikeG
Netherlands 2007 Range Rover Vogue TDV8 Santorini Black
Andy, I had this a couple of months ago and the double press of the mirror button did the trick... Although I must say don't give up... I recall I had to do this at least a dozen times back to back after which the system reset itself again and all has been fine ever since. Mike.
2007 Range Rover Vogue TDV8, Black, Sand Leather Seats & Sand / Black Interior.
IID Tool from GAP Diagnostics.
Post #232267 1st Jan 2014 3:00pm
