Home > Technical (L322) > Non starter 4.4 v8 |
Saltyfish Member Since: 19 Jun 2012 Location: Yate/Bristol Posts: 22 |
Went to start my 4.4v8 early this morning after a day of it being stood up. Turned over but would not start (it was fine 24hrs ago). I have checked fuel pump and that is fine i also checked fuel is being delivered at fuel rail and thats fine.
30th Dec 2013 2:28pm |
Yes have tried that, have also now checked fuses in E-box.
30th Dec 2013 4:10pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35265 |
the battery has to be 100% for all the ecu's to function....i'd test that first.. ... - .- -.
30th Dec 2013 4:19pm |
daz62 Member Since: 27 Dec 2011 Location: Reading Posts: 201 |
Apparently the ignition switch can fail, this similar problem to yours ended up being a broken connection in the fuse box.
30th Dec 2013 4:30pm |
Battery is at 100% charge. 04 Vogue 4.4LPG.
30th Dec 2013 4:31pm |
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2575 |
Any unusual messages coming up as I had a similar issue a year or so ago, but it threw up a ' CODE ----' on the display, Turned out to be a faulty instrument cluster |
30th Dec 2013 5:45pm |
There appears to be no power to the dash apart from the mileage display. I'm now thinking a fuseible link (no 2) may have blown as this appears to power everthing that has stopped working. 04 Vogue 4.4LPG.
30th Dec 2013 6:11pm |
UPDATE.
31st Dec 2013 3:26pm |
UPDATE.
3rd Jan 2014 4:05pm |
did the garage diagnose and repair? |
3rd Jan 2014 4:10pm |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1899 |
Great news
3rd Jan 2014 4:58pm |
The AA diagnosed and i repaired.
4th Jan 2014 10:30pm |
