Home > Maintenance & Mods (L322) > No rear washer water?
pld118
Hi,
When trying to activate the stalk, the rear wiper works but no water comes out. No issues with front washers and no water, dirty or otherwise, pours down the inside of the rear tailgate.
Are there some basic checks I can try to please determine what the issue might be (We've never tried to use this washer since getting the car so not sure if it's always been like that or whether something occurred in the interim)?
Thanks.
Post #231807 29th Dec 2013 7:15am
stenh02
Scotland 2004 Range Rover Vogue 4.4 V8 Rimini Red
I think this is a common fault in the L322 due to the path of the water thru the centre of the spindle of the rear wiper mechanism.
You can pull the top panel off the tailgate to expose the mechanism and check the pipe is still attached to the wiper mechanism and you can pull the end of the pipe off to check if water will come thru when the pump is activated.
There are some pictures on here if you search.
G
Post #231809 29th Dec 2013 8:06am
stenh02
http://www.fullfatrr.com/forum/topic884.html?highlight=rear+wash
Has the info required
Post #231810 29th Dec 2013 8:08am
mjdronfield
The rear nozzle is prone to getting covered in crud over the years as some owners don't always remember to clean it as it's hidden under the rear spoiler.
Mine was a bit hit and miss when I got it. Bought a nozzle cleaning tool, didn't help. Garage had a look and they got it a bit better, but took a few seconds for water to appear when holding the stalk forward. Managed for a bit. Then had the plastic non return valve changed. Slightly better. Gradually had less and less water coming through over time. Garage stripped it all down and was fine for a few months, then same again.
The water has to pass through the middle of the motor, so there are various seals inside as you may have read.
Eventually my rear wiper motor stopped working, and would only move the arm 2 or 3 inches across the screen at a time, if at all. Always good for the look having the rear wiper stuck vertically down.
So £229 later I have a new wiper motor installed and water is there instantly and always.
The warranty paid for the cost, but it's not cheap.
There is a full rebuild thread on here in case you want to try a clean out yourself. It's a bit pricey otherwise if you only have a washer issue.
Ah - link posted above whilst I was typing.......
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #231811 29th Dec 2013 8:10am
pld118
Thanks Thumbs Up
Post #231813 29th Dec 2013 8:27am
Are you sure it's not simply gummed up with polish, Ryan? Razz Si. <This is my name.
Post #231819 29th Dec 2013 9:22am
Or the nrv in the water feed is stuck shut, little black jobbie about 1" long, also in the top boot trim.
Worth a check as they are a couple of quids, and might be a simpler fix. There is nothing that can't be fixed with a hammer😜😜
Post #231821 29th Dec 2013 9:47am
pld118
Thanks both, will check. I think if not a simple clearing job, this will be covered under warranty and if not, so be it.
Post #231828 29th Dec 2013 10:31am
I tried to get mine done under the lr warranty and it wasnt covered, however the wiper arm isnt too expensive and only takes a few mins to fit, same with the nrv. There is nothing that can't be fixed with a hammer😜😜
Post #231836 29th Dec 2013 10:38am
mjdronfield
For Info ;
I was charged / have paid ;
Rear Wiper Motor £168.85 + VAT (£22 fitting)
Wiper arm £28.32 + VAT
Non Return Valve £5.83 + VAT
I believe they are full retail prices, before any discount.
Best to use Dan at Duckworths for parts if you can, as he is a site sponsor and can offer better prices.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #231844 29th Dec 2013 11:30am
Sounds about right mjd, think my wiper was about that fitted during a service. There is nothing that can't be fixed with a hammer😜😜
Post #231854 29th Dec 2013 12:52pm
