Home > Technical (L322) > TRANSMISSION OVERHEAT
Scorchio
United Kingdom 2003 Range Rover Vogue 4.4 V8 Buckingham Blue
Guessing this is an easy one ...
2003 4.4 Vogue, drives fine on the average small journey up to say 150 miles. But any longer than this and won't select 5th gear, happy in 4th at quite high revs. Then 20 minutes later same happens with 3rd.
In sport mode you can normally get it into 4th at high speed.
Then 20 minutes later get "Transmission overheat" on the LCD.
Ok, ok, so the transmission is overheating - got that bit !
How do i fix it and what should it cost me at my local independant ?
Thank you in advance ! 2003 Vogue 4.4
2005 BMW 330d
Gone - 2002 TD6 HSE
Post #21313 30th Jun 2010 5:16am
dan_uk_1984
The manufacturer of the gearbox specifies that the oil is changed every 50,000 miles, any time the g/box is overheated the useful life of the oil is halved too as ATF breaks down much faster if it heats beyond it's tolerance.
Old sludgy oil with a partially blocked filter could be causing your overheat problem.
Additionally the oil cooler is a known weak point, so couple this with old oil and you'll get a problem in no time. When was the last time it had a coolant change/flush? Is the correct coolant being used? Has anyone ever mixed red and green/blue etc? As this then reacts and causes loads of sludge.
Dan
Post #21316 30th Jun 2010 7:38am
Nappler
2003 Range Rover Vogue 4.4 V8 Java Black
I've heard this can be due to a partially blocked radiator as the bottom few tubes cool the gearbox or something?, quite a common issue on them, definatly change the gearbox oil and worst scenario might be a new rad too.
Post #21321 30th Jun 2010 8:01am
Scorchio
Nappler - same problem as you ! sorry for a duplicate thread !
All,
Had the gearbox oil changed by my local independant on Friday - fyi, cost £131.60 ... think I am happy with that !
Anyway, yesterday the problem was still happening. Obviously needed doing since garage said that the oil that was drained wasn't pretty !
What is the next thing to try guys ?
Regards
Scorchio ! 2003 Vogue 4.4
2005 BMW 330d
Gone - 2002 TD6 HSE
Post #23166 26th Jul 2010 10:33am
Nappler
Scorchio did you change the rad too?, I have and the only thing I can think of now is either an airlock or it's got to be an iffy gearbox sensor.
In the last week my car has had a new rad,new water pump,new alternator(this suddenly went too),new gearbox oil,new coolant, it's starting to get more than a little irritating!.
Does yours come up with the transmission overheat message still?, as mine doesn't it just seems to go into the gearbox setting for it now and then, although once turned off then on it's ok.
Post #23167 26th Jul 2010 10:43am
Scorchio
Nappler - optimistically thought the oil change would fix it ... so no - haven't done anything else as yet ...
No, didn't get the overheat message yesterday, but don't normally until a good half hour of driving after the gearbox has gone whappy - by which time I was home yesterday. 2003 Vogue 4.4
2005 BMW 330d
Gone - 2002 TD6 HSE
Post #23168 26th Jul 2010 11:27am
DeltaC
I had the same symptoms, changed the oil and the filter, still had the problem. Then changed the radiator and the heat exchanger, problem went away. Filter was black, radiator was blocked on the bottom few tubes.
Bearing in mind that when you drain the oil, you only get less than half the total volume the box uses, out. The rest is in the torque converter etc. Not sure how the garages "flush" (or if they do).
It is fairly easy to check the colour of the oil - if it is still dary after the change, I'd do it again. I'd also confirm with the garage that they did the filter and cleaned the sump out.
Post #23170 26th Jul 2010 11:52am
dan_uk_1984
It is possible to flush the box, it involves taking a hose off somewhere and letting it pump the new oil in and the old oil out.
Not exactly sure on the procedure and never liked the idea of doing it!
Post #23183 26th Jul 2010 1:50pm
Nappler
I'm sitting in a petrol station at the moment after the car has done it again, guess I must have a blocked oil cooler, it's all I can think of now, since I've owned the car it's been off the road more than on!, and I thought a TVR was unreliable.
Post #23191 26th Jul 2010 2:11pm
dan_uk_1984
Problems caused by poor maintenance (by previous owner) can't really be blamed on reliability...
I'm just having a flick around online to see if there is any way to read the emperature of the box without T4 and I can't find anything. I know my OBDC software doesn't read g'box codes or temps.
Post #23192 26th Jul 2010 2:17pm
Scorchio
ok, excuse my complete incompetence ...
So I'll change the filter but realistically this is unlikely to fix ?
What sort of cost for a new rad including fitting from an independant would you say ?
thanks guys - I am clueless 2003 Vogue 4.4
2005 BMW 330d
Gone - 2002 TD6 HSE
Post #23206 26th Jul 2010 3:57pm
dan_uk_1984
I'm confused now as to who in this thread needs the help!
Scorchio - when they changed the fluid, did they change the filter too? If not then when the oil overheats it can start to sludge up, when this happens the filter starts to block which in turn causes slower oil flow = overheat.
I'd be amazed if they did an oil change without changing the filter....
Post #23219 26th Jul 2010 4:38pm
Nappler
Was in the mechanics earlier and box temp was about 113-114 after the car was left idling in park.
Got a new oil cooler ordered and will be getting fitted on wednesday, the only things left it can be are the cooler or the sensor itself.
I know it's not really the cars fault, just getting a bit frustrated with it at this point!.
Post #23271 26th Jul 2010 9:52pm
Nappler
Rad fitting shouldn't take more than an hour, I paid £167 for a new rad from Autopost.
Post #23272 26th Jul 2010 9:54pm
Nappler
The oil cooler was blocked, the car sat in traffic for 30 mins yesterday and was fine, it seems the problem has been fixed.
Now I can finally start enjoying my RR without worrying about it going into cooling mode.
Post #23643 29th Jul 2010 9:25am
