Home > Maintenance & Mods (L322) > Headlight versions
MarkT
United Kingdom 2008 Range Rover Vogue TDV8 Java Black
Headlight versions
Hi
I’m undertaking a headlight modification and wanted to clarify the versions available. I have a Vogue MY08 which has a Xenon as a driving light and a normal halogen for main beam. The Xenon looks to be on a movable bezel I assume for bending the light as steering (haven’t driven in the dark yet Embarassed )
I believe this is the standard light however think there was also an upgrade to Bi Xenon, is that correct and if so is the second Xenon in the same place as the halogen ?
Thanks in advance - Mark
Post #23164 26th Jul 2010 11:12am
daveo
hi mark, i think you will find that the bi xenons still have a halogen high beam lamp but on the xenon lamp there is a solinoid shutter set up, so when you flick high beam the shutter flips open giving you the high beam on the xenon lamp as well as the aligon lamp.,
i think i am right but i will stand corrected.
dave V8 facelift Range Rover Autobiography 22" wheels.
Post #23205 26th Jul 2010 4:56pm
M44K TS
I'm pretty sure you're right daveo, I'm sure my dipped xenon flicks up with the main beam. 2006 Mercedes CLS
1991 Retro-style Mini
But really finding it hard to fight the urge for a S/C...
Post #23256 26th Jul 2010 9:41pm
daveo
i did come accross a mod, they had fitted after market xenon packs to were the haligons lights had been and they worked fine..but xenons need a few minuets to get to there working temp, and as when you flash some one it would be a few seconds only and they wont be warm enough,so unless you do a lot of country roads and use high beam alot i cant see the benifit..
but that just me V8 facelift Range Rover Autobiography 22" wheels.
Post #23260 26th Jul 2010 9:50pm
