Home > Technical (L322) > Windshield wiper arm removal |
To remove the arm you will need a small 2 arm puller, lift up the cover (no 4 in lower image), remove the nut and washer (no 5 & 6 in lower image) and put the puller onto the back of the arm and tighten the puller onto the spindle then gently tighten the puller bolt. The arm will pop off if done properly
24th Dec 2013 1:15am |
funnyguy1 Member Since: 11 Mar 2010 Location: Sun Valley, Idaho Posts: 383 |
Thank you 47p2, what is a "small 2 arm puller"?? Mike |
24th Dec 2013 4:34am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35312 |
most times you can jiggle the arm off with a screwdriver.. ... - .- -.
24th Dec 2013 8:26am |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1698 |
Remember to put the new arm on at the right angle to the screen or you will get that knock sound as it starts or stops it's wipe action. (apparently 86 degrees against the window when parked - thanks IT Guy)
24th Dec 2013 9:12am |
mine came off easily with a screwdriver but the angle adjuster plate was stuck fast.. ... - .- -.
24th Dec 2013 9:25am |
Sorry Stan - you are correct - it was the adjuster plate that is hard to shift without pullers. And it's this that needs to be moved if the angle is wrong..! Ash
24th Dec 2013 9:28am |
24th Dec 2013 9:29am |
paneldamage Member Since: 11 Nov 2010 Location: Preston Posts: 222 |
The angled/grooved seating plate is pressed on to the spindle, it needs a puller to get it off. You don't need to remove it to change the angle of the arm though.
25th Dec 2013 4:15pm |
adigorn Member Since: 18 Mar 2010 Location: West Midlands/Birmingham Posts: 204 |
There might be no seating plate on 11my
25th Dec 2013 4:25pm |
drakes Member Since: 26 Jan 2009 Location: Consett Posts: 370 |
I had to cut off my seating plates as I could not shift them with a puller. The later wiper arms do not seem to have the seating plates. 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
26th Dec 2013 1:21pm |
