![]() | Home > Technical (L322) > 2010 4.4 TDV8 vogue |
JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204 ![]() ![]() ![]() |
I think you need to look at the calliper as if it's Brembo it will have it cast into the body. |
snowsports1 Member Since: 19 Dec 2013 Location: hampshire Posts: 5 ![]() ![]() ![]() |
ok thanks it doesn't, it says range rover so I will buy the non brembo discs. just looking at famous four website. |
You have the later ones, always an answer on here most of the time not from me as the others are proper boffins.
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16315 ![]() ![]() ![]() |
Yes sir you do have Brembo's if the callipers are grey with Range Rover on them... 10my onwards don't have Brembo on them only as yours are... Jas, yours too are Brembo's pal ![]() |
ok that was close now buying brembo discs and pads. the dephi pads are much cheaper mind you, are the genuine brembo pads worth it? |
Your car has the later 09- big Brembo's on it not the smaller 05-09 smaller Brembo's
IMHO I would only ever fit OE pads |
I want bigger |
Thanks Craig
No worries |
At least you have brakes. My TD6 with a full trailer load......it does stop eventually. ![]() |
What makes you think I was referring to brakes Kurt |
