![]() | Home > Wheels & Tyres > correct 20ins tyre size |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1521 ![]() ![]() |
20" on the full fat are 255 50 20
Load rating should be 109 also. Present :2008 TDV8 HSE
These are factory standard: -
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3756 ![]() ![]() |
275/45/20 are the closest in diameter to the oem 255/50/20, but are 20mm wider. |
So in theory ride should be better or worse? Present :2008 TDV8 HSE
In theory better if they are 275/45/20 as the tyre wall depth is almost the same but they are 20mm wider. If they are 275/40/20 then worse as there is significantly less tyre wall depth.
hammiegt Member Since: 28 Sep 2013 Location: wrexham Posts: 125 ![]() ![]() |
cheers for your informed replies guys, as I said, the tyres on are as new, so they will have to stay put for the time being, just thought they look a bit small, plan to change the wheels next year, and will make sure I have the correct tyre size on
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16306 ![]() ![]() ![]() |
Basically you have RR Sport tyres fitted... Probably came from a sport originally before being fitted to your car... So, your choices are not as limited as you maybe first thought? Sell them back to the RRS fraternity is another viable option |
As Craig says - I would also flog them and buy some the right rolling radius - you would save money in the in unburnt fuel as your gearing is slightly lower with 40 profiles |
chrisw Member Since: 17 Dec 2013 Location: nottingham Posts: 10 ![]() ![]() ![]() |
Autodata lists 255/55R20 or 265/55R20 on 8,5x20 rims, I've just bought some Sport wheels with some knackered 275/40R20's on them, I've just spent £552 on 275/55R20 Hankooks.
275 55's are entirely wrong im afraid... 255.50.20 are the correct size for a FF |
255's won't fit, it's got range rover sport wheels on it 9,5j or 10j I can't remember which!
And above it says ---/50R20!!!! Goddammit!!!!!!!! |
Standard Diameter 763mm
