Home > Technical (L322) > iiidtool, what have you changed in the ccf?
as title , i'm curious what functions you have enabled/disabled..
i've turned the steering wheel retract off,
tpms off,
increased the rear pdc volume ,
auto door relock was switched off,
beep on lock and unlock, love this Mr. Green ,
key in ignition off .
i havnt touched the suspension yet but will probably play with it when it gets a bit warmer.. ... - .- -.
Post #230091 19th Dec 2013 4:48am
Googsy
Morning Stanley
I have turned off hot and cold monitoring on my lights as this prevents leds flickering on start up same as leds so if yours are flickering disabling will sort.
Also enabled auto lock
Turned on alarm chirp like that too
Also was able to reset steering angle sensor as was slightly off when wheel was straight.
Enabled indicators to flash 3 times when changing lanes etc with one touch without need to cancel.
Thats about adventurous as I have got ... Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #230092 19th Dec 2013 6:56am
hot/cold monitoring on certain bulbs is something i must do Conner Thumbs Up ... - .- -.
Post #230102 19th Dec 2013 9:22am
Andy
How do you do the indicator x3 flash? I'd like that
Post #230152 19th Dec 2013 12:04pm
Katash
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
IIRC you have to have a BCM with a certain firmware on it to enable that feature, I dont think <05 MY's can be done without swapping out the BCM
.... Maybe I'm wrong tho.
Post #230195 19th Dec 2013 3:24pm
i looked at the GAP site and couldnt see that option for the 02-05 ranges..... ... - .- -.
Post #230209 19th Dec 2013 4:17pm
RR2008HSE
Please delete
Post #230331 20th Dec 2013 12:56am
Andy
I suppose this is where I find out that there are only certain functions available being a 2002-2005 model!
Post #230443 20th Dec 2013 2:10pm
put your year into the drop down menu and it'll tell you what you can change,
http://www.gap-diagnostic.com/products/iidtool.html ... - .- -.
Post #230445 20th Dec 2013 2:13pm
33CHINACARS
Australia 2017 Range Rover Autobiography SDV8 Santorini Black
Enabled auto lock
Enabled one touch up & down on front windows ( think that's what it's called )
Plus a few other thing's I cant recall
Gary
Post #231868 29th Dec 2013 2:23pm
RR2008HSE
Would you do a 'How To" for the auto-lock feature? Thx Bow down
Post #232079 30th Dec 2013 11:47pm
auto lock on/off is in the BPM- body processor section...[speed related locking] ... - .- -.
Post #232089 31st Dec 2013 8:57am
RR2008HSE
Thanks, Stan Bow down
Post #232216 31st Dec 2013 9:27pm
SteveMFr
Site Sponsor
Thank you Stan! Cheers!
And a happy new year to everyone from all of us!!!
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #232218 31st Dec 2013 10:02pm
and all the best to you Steve and the GAP chaps.. Thumbs Up ... - .- -.
Post #232220 31st Dec 2013 10:44pm
