![]() | Home > Technical (L322) > road |
samp5679 Member Since: 25 Sep 2013 Location: houghton le spring , north east Posts: 26 ![]() ![]() |
deleted |
RCusden Member Since: 12 May 2012 Location: NarberthPembrokeshire Posts: 186 ![]() ![]() |
Yes I had that as well as other fault codes when I had the air suspension inactive message. I had to replace the compressor which fixed mine. I tried a rebuild kit but I was the unlucky one and it didn't work but plenty of people on here have been lucky with the rebuild kits or a new piston ring. There is also a thread on here where it was the valve block that controls the air flow to the air bags that also threw up that code.
thanks roger , air compressor replaced last year
This is the thread I was on about
