Home > Technical (L322) > Glow plug test ? |
fairwx Member Since: 10 Nov 2011 Location: bristol Posts: 124 |
maybe wire it up to a 12v bat for few seconds to see if it glows..
12th Dec 2013 6:21pm |
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 |
you can check the resistance with a multimeter - cant remember correct range but its very low - something like 0.4 - 0.9 ohms. |
13th Dec 2013 8:21am |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1347 |
13th Dec 2013 8:52am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3978 |
As above, the easiest way is to connect it to a battery and see if it glows, should be almost instantaneous.
13th Dec 2013 9:17am |
And either pulse it or take it off after 1 second or it may burn out. |
13th Dec 2013 11:49am |
Steverr Member Since: 27 Oct 2013 Location: Bristol Posts: 191 |
thanks guys will give it a glow.... ha ha get it ,,, did you see what I did !!! Glow .. Go... |
15th Dec 2013 3:38pm |
