Home > LPG > Removal of filler pipe
TOF
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Stornoway Grey
Hi All. I am going to be changing the location of my lpg filler... If i undo the filler pipe from the tank on my BRC system, will any gas leak out...
Thanks in advance,
Chris
Post #228993 13th Dec 2013 9:02pm
i honestly wouldnt mess with any thing like that..get a lpg dealer to do the job.. ... - .- -.
Post #229003 13th Dec 2013 10:10pm
The only gas that can leak out is the gas in the filler pipe... There has to be a non return valve in the tank where the filler pipe connects...
Quite agree with Stan though, best left to the professionals Thumbs Up
Post #229371 15th Dec 2013 7:10pm
dhallworth
We did the complete LPG install on our P38 ourselves and had it certified after we'd done it. There's nothing complicated about it as long as you're mechanically handy.
As Craig has said, there's a one way valve in the tank so you might get a little hiss of gas escape as you undo it or a long hiss if the one way valve is Censored . It should be a simple case of unscrewing the union, moving it and screwing it back on again. If you're doing it yourself get some leak detector spray or soapy water and spray any unions you undo after filling up so you can be sure they're not leaking. Thumbs Up
On both of our P38's we've only got the black 12N towing socket on it rather then both so we used the other towing socket cut out in the back bumper to locate the filler. Looks really neat and saves having to cut another hole in the car. That might be a Censored on the L322 though as the towing sockets are much further under the bumper.
Post #229390 15th Dec 2013 7:43pm
