Home > Technical (L322) > Big Engine Problem |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2032 |
have you now confirmed that although running rich/smokey , that the dodgy injector/plug is now firing, so running on all 8 cylinders? plug is black, but DRY? can you check that you don't have an air leak on the induction. when you changed the pcv, did the cyclone tube get checked/changed? is that blocked? (at rear of engine) |
13th Dec 2013 4:40pm |
FTS999 Member Since: 18 Jul 2013 Location: Wiltshire Posts: 37 |
Sorry forgot to mention it's still misfiring and No 1 is still wet. all the others are black with soot.
13th Dec 2013 4:51pm |
mmmm, so you changed air filter, and then white smoke, or did you change PCV and white smoke or both together...like I said, you seem to have two faults. smoke, and misfire.... but I wonder if engine is shutting down cylinders, in an attempt to aleiviate smoke? with info from cats. you must have the engine light on, on the dash yes? |
13th Dec 2013 5:11pm |
PCV & MAF was done after the problem started.
13th Dec 2013 5:32pm |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
So you disconnected the injector on 1 and basically it stopped smoking. I think that proves you had unburnt fuel being shoved out past the valves and causing the smoke. You assumed it was a faulty injector so replaced it and the problem came back... It sounds to me like it is not firing on 1 and is electrical, not an injector.
13th Dec 2013 6:36pm |
Yes that is exactly what we thought.
13th Dec 2013 6:45pm |
Does the plug spark? Have you taken it out, held it against the block and actually seen a spark as it turns over?
13th Dec 2013 6:52pm |
The electrician said there was a good spark on all 8 cylinders so I haven't conducted this test myself |
13th Dec 2013 7:01pm |
I will go back to basics on Monday.
14th Dec 2013 1:06pm |
I would keep it concentrated on cylinder 1 to start with as that seems to be worst one... Previously..
14th Dec 2013 3:01pm |
Do the ECU's pack up on these? |
14th Dec 2013 4:13pm |
as I mentioned earlier., you need to remove the coil pack (on suspect misfire cylinder), and fit ANOTHER spark plug to it, and leave it wired in, with a disconnected a plug in the affected bore., as engine will start when cranked! run a test lead from earth to the plug body the plug in the coil pack), or a good jump lead. observe if the coil pack and plug are sparking. try and do it in bad light, it makes it easier to see. lower bonnet down if sunny...its possible you have a spark signal pulse, but no earth return. ie the coil pack has two connections, pulse and earth. if you can prove a spark/no spark, you know where to think next. ie pub/kettle.. |
14th Dec 2013 8:52pm |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2257 |
I had a similar problem on a p38 v8 and did a smoke test with a smoke machine and had a slight weep air leak on inlet manifold but also although no 2 was sparking it was sparking weak and at the wrong temp new plug and reseat of the inlet manifold job done but it was the smoke test that helped hope this helps |
14th Dec 2013 9:29pm |
Thanks guys,
15th Dec 2013 11:31am |
