Home > Maintenance & Mods (L322) > fluid and filter td6
td6vogue
hi
whats the best place to get a transmission filter and oil
also how much oil is required
thanks
Post #228317 11th Dec 2013 11:32am
Filter (Genuine) and gearbox sump gasket from Dan@Duckworths
Transmission fluid from here,
http://www.fleetfactors.co.uk/lubricants-c...7045e-p387
Cheaper to buy 20L and then you can change the fluid 3 times to ensure a good dilution of the existing fluid.
Post #228406 11th Dec 2013 6:39pm
could be some bargains from Oilman our other site sponsor ,
http://www.fullfatrr.com/forum/topic22423.html ... - .- -.
Post #228407 11th Dec 2013 6:40pm
td6vogue
what grade oil is best for the gearbox on a td6 l322
im not sure if its ever had a oil change before, im on 94k now
Post #228512 12th Dec 2013 10:19am
SteveMFr
Site Sponsor
There have been several discussions on ATF in the forum
I would def stick with the OEM spec Texaco 7045E. You will also need either a diagnostic tool or an infrared thermometer to check ATF temp when refilling the trans. Follow the procedure in the shop manual!
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #228515 12th Dec 2013 10:29am
