Home > General > how a ffrr looks
And I would NOT recommend anyone doing that to their car.
If you want a low riding car, buy a sports car. Discovery 4 HSE
Post #22704 19th Jul 2010 10:29am
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
Having driven for long periods at 140mph (not in the UK) I can confirm that the 2006 and 2010 DO NOT lower at 100mph+ - or if they do there is no indication of this on the 4x4 display (as shown in the handbook!). Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #22705 19th Jul 2010 10:41am
dan_uk_1984
I’d be very interested to see some info on the “Extended Mode” that has been mentioned, especially for the 2002-2005 MY. I know this was a feature on the P38, there was mention of it in the manual as well as the workshop manual. However there is no mention of this in the L322’s WSM or handbook. As the EAS system is from BMW I presumed this is why this feature is missing.
I would be happy to be proved wrong as I think it was a fantastic feature of the old system, basically it meant that if you went too far and got grounded, you could always back out, or if you were brave, continue with those extra few mm.
Post #22709 19th Jul 2010 11:14am
When mine was putting it self in to extended mode the OBD would say Suspension in extended mode clear obstruction before lowering , or words to that extent . 2008 MY Supercharged
Post #22739 19th Jul 2010 2:10pm
DMRR
2010's certainly have extended mode, it is documented in the handbook - although the instructions to *manually* invoke it do not work. Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #22742 19th Jul 2010 2:24pm
dan_uk_1984
After BMW Cut LR free the tech changed a massive amount though. Personally I love the direction they have been taking over the last 5 years, leaps ahead of BMW - again. Give it another 10 years and BMW will buy them again to catch up.
Post #22745 19th Jul 2010 2:35pm
JMC
Scotland 2012 Range Rover Westminster TDV8 Orkney Grey
You are wrong and right in the same sentence...... Shocked
They DO drop a bit at 100mph and they come back up to 'normal height' again if the speed drops below about 80-90mph. However, there is no indication on the display - principally because the drop is 'normal' for these speeds but isn't classed as 'access height'.
I can't speak for the MY10, but FWIW the FFRR TDV8 works exactly the same way as the Disco3 in terms of:
  • Access Height
  • Normal (High Speed) Height
  • Normal Height
  • Off Road Height
  • Extended Mode
  • Super Dooper Extendy Height Mode
Items shown in bold are selectable by the driver. The others are not. Rolling Eyes
To get to Super Dooper Extendy Height you must first 'ground' the car, or fool it into thinking it is grounded (eg. using a trolley jack). The car goes automatically from Off-Road to Extended Mode. The display shows an obstacle and asks you to re-set the height once you are clear. At this point, put your foot on the brake, keep the brake on and press & hold the raise button for five seconds. Hey presto! Razz
A couple of points to note about being this high though...... The car will drop back to Off Road if you go above about 10-15mph at Super Dooper Height. More importantly, don't try to get out of the car without looking as you will end up falling on your face. There is honestly enough room beneath the car to roll under it from one side to the other and work on the exhaust with spanners in the process! The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #22809 20th Jul 2010 2:16pm
nbunney
JMC
2 questions
Do you know if the super extended height work on a TD6 in the same way?
And where would you place the jack to think it was grounded? and would you possibly put a switch in place?
Cheers
Post #22812 20th Jul 2010 2:39pm
DMRR
The 2006MY has an entry in the handbook about the high speed suspension drop of 20mm. The 2010Y handbook makes no mention at all of this function - so I can only assume it has been removed and the suspension tweaked.
Just checked them out on the http://www.ownerinfo.landrover.com site as I didn't think I was going mad Thumbs Up Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #22813 20th Jul 2010 2:41pm
paul_h_8
2002 Range Rover Vogue Td6 Bonatti Grey
Couldn't agree more
Post #22815 20th Jul 2010 2:43pm
Full fat not diet
England 2004 Range Rover Vogue Td6 Zermatt Silver
Or a "Low Rider" from the US Cool
Post #22816 20th Jul 2010 2:50pm
JMC
nbunney wrote:
2 questions
I'm afraid I'm not the man to answer your questions. Whistle
I've never suffered had the pleasure of a TD6 so I just don't know. Also, I tend to take the car off tarmac to play with it so I just ground the thing to make it work the way I want it to. Mr. Green
I'm led to believe however that raising (or attempting to raise) a wheel with the engine running will send the car rushing into extended mode. Whistle
Switch??? Confused If you mean fitting a switch to make it do this then I wouldn't go there myself. Neutral The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #22821 20th Jul 2010 3:38pm
Turbo Tony
I'd like the car to drop a little at a speed lower than 100mph. I don't often drive that fast Whistle but would like the benefit of a lower centre of gravity at standard UK motorway speeds.
I wonder if there's a tweak to tell the facelift (06-09) model to drop its height a little sooner? Researching my first Range Rover purchase
Post #22841 20th Jul 2010 7:56pm
