Home > In Car Electronics (L322) > No GPS signal
g1968g
No GPS signal
Hi,
My GPS icon with a line through it is on. Is there anything I can do to fix this.
Cheers
Geoff
Post #227490 7th Dec 2013 9:53am
B9er
Northern Ireland 2010 Range Rover Autobiography 5.0 SC V8 Java Black
If you have the roof mounted gps ariel, then it is probable the antenna has failed. Easy to check, just buy a new Fakra terminated antenna off EBay for about £6. Plug it into your gps unit in the boot and see if your position is found. If it is, then you need to take off the roof mounted antenna and open it up, remove the old antenna and epoxy glue in the new one. Voila a working GPS again.
There are threads giving detail of how to do this, if you search. Should've been old enough to know better...doh!
Current 2010 5.0 SC Autobiography
Previous 2006 TD6 Vogue SE
Previous 1998 P38 4.6 Vogue Autobiography 50 (No 10)
Post #227576 7th Dec 2013 7:34pm
