![]() | Home > Maintenance & Mods (L322) > rear wheel alignment ??? really .!!! |
Yes, four wheel alignment is a must. Your rear wheels have adjustable camber/(caster) and toe in/out and these need to be set after replacement bushes at the rear, otherwise steering and tyre wear will be affected.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
Yep quick fit do have very good hawkeye setup at selected centres! They will normally do a free check, then charge to adjust the amount seems to Based on the amount of work required, as the camber/toe will be affected by the replacement of the rear bushes then it is a must, however shold be easy to set as the bolts will have recently been freed off |
PROTYRE did mine for £50. I believe there is a specific 4 wheel drive piece of testing kit required? |
Hawkeye has the settings for all cars including ffrr, wheels have sensors fitted and a a laser on the base unit scans the wheels to guage the camber castor and toe of all 4 wheels.
greasemonkey1 Member Since: 22 Sep 2013 Location: london Posts: 157 ![]() ![]() ![]() |
CHEERS GUYS... |
goldsax Member Since: 16 Jul 2012 Location: leicestershire Posts: 196 ![]() ![]() ![]() |
Hunters wheel alignment system is probably the best known.
DaveK Member Since: 18 Oct 2013 Location: StHelens Posts: 791 ![]() ![]() ![]() |
Another heads up for KwikFit. Mine drove like a different car once I had it done at KF with the car feeling like it had just rolled out of the factory. |
