Home > Technical (L322) > PDC Parking Sensors fault |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16281 |
If its the rear and your getting no joy from either of the four sensors then the plug for the rear loom is located under the bumper skin underneith the drivers side rear lamp, so i would start there and make sure the plug is connected correctly and the connections are clean |
3rd Dec 2013 11:55am |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1511 |
There could also be a short where the harness crosses under the plastic and over the metal bumper (DAMHIKT)
3rd Dec 2013 12:23pm |
webber Member Since: 26 Nov 2013 Location: Stockport Posts: 29 |
Thanks for the advice
3rd Dec 2013 1:53pm |
It's easier to take the bumpers off, then you can totally rule it out.
3rd Dec 2013 2:27pm |
stevegt Member Since: 17 Apr 2010 Location: Worcestershire Posts: 255 |
If none of he sensors are ticking (front or rear) the the fault is most likely with the rear sensors as the contol module will deactivate both. Issues with the front will only deactivate the front.
3rd Dec 2013 2:46pm |
TugRR Member Since: 11 Jan 2011 Location: Bakewell Posts: 1199 |
Just a quick add on to Steve's above - rear bumper is easy, unless first you have to remove the mud flaps. A grinder may be required. If your car has them, just give yourself a bit of extra time -
3rd Dec 2013 3:16pm |
Great info, thank you very much for that.
3rd Dec 2013 4:55pm |
Ok bit of an update... I took the bumper off and decided to replace the rear wiring loom to the sensors as I was convinced there was a broken wire in there somewhere and the loom was only £40 so it seemed worthwhile.
23rd Dec 2013 11:55pm |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3779 |
I couldn't hear mine ticking either, I thought I was going deaf so I went to the Doctor who all covered his bases and diagnosed "Sensory Impairment" boom boom
24th Dec 2013 8:06am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35268 |
if the sensors and the wiring are ok then the next step is to replace the pdc control module... ... - .- -.
24th Dec 2013 8:25am |
Despite my poor joke, mine have only worked immediately after a reset for a few seconds in the 3 years I have had the car. The IIDTool suggests that both the front offside and the rear offside sensors have a fault, is that likely to be an accurate diagnosis (is each sensor individually checked) or is that just generic for any of the sensors being suspect, and as I said no clicking as by the time I get round to either the front or rear as the system seems to have shut down
24th Dec 2013 8:54am |
jarv Member Since: 12 Jun 2013 Location: London Posts: 30 |
Any update on this Adam as I have a similar issue with my PDC?
11th Feb 2014 9:48am |
gav Member Since: 03 Jan 2014 Location: Hertfordshire Posts: 37 |
I have a funny issue with my PDC on my 53 4.4 vogue
25th Apr 2014 6:31pm |
Water ogress into the sensors probably... 06MY 4.4 V8 Autobiography Cairns Blue with Navy & Parchment Interior |
25th Apr 2014 7:58pm |
