Home > Technical (L322) > battery jump start possible solution?Battery Regulator Modul |
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 |
Hi there, sorry to hijack your post, but why is jump starting a no no on FFRR?
1st Dec 2013 3:51pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
TBH, never had any problems jump starting to or from the FFRR, one just has to follow the correct routine as indicated in the handbook. .
1st Dec 2013 4:47pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7925 |
+1
1st Dec 2013 5:05pm |
goldsax Member Since: 16 Jul 2012 Location: leicestershire Posts: 196 |
i have been told by both RR dealer and indie that the ECU's can become damaged due to surges/spikes in the supply.
1st Dec 2013 8:51pm |
a gimmick?
1st Dec 2013 8:57pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3972 |
I'm not really sure what sort of "surge" these jump leads are protecting against.
1st Dec 2013 9:20pm |
tboner001 Member Since: 22 Jan 2011 Location: Bucks Posts: 691 |
Funny that as land rover assist have jump started my l322 and Sports in the past and no issues
2nd Dec 2013 10:24am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35267 |
if you follow the instructions in the owners manual you shouldn't have any problems.. ... - .- -.
2nd Dec 2013 10:30am |
great,
2nd Dec 2013 10:36am |
drivesafe Member Since: 19 Mar 2008 Location: Gold Coast Posts: 126 |
Hi goldsax and here is the standard jump-start procedure, for any vehicles, not just an RR.
2nd Dec 2013 11:27am |
2nd Dec 2013 11:34am |
What does that mean in English ? Is the cranking battery the good one ? So if I give someone a jump start - once they are started, I should stop my own engine before disconnecting ? I was actually told that you're supposed to stop both vehicles before disconnecting - but as other advice is that the newly started car should be kept running - I go with leaving them both running. That said, I also use Anderson connectors on my cars, so the connections are as good as you can reasonably get & disconnecting is quick and clean. It's the spiky voltages that come with poor connections that do the damage, not the change in voltage. |
2nd Dec 2013 7:43pm |
Hi Alistair and sorry I should have replied sooner.
10th Dec 2013 2:27pm |
well done on a great reply..
10th Dec 2013 3:47pm |
