Home > Technical (L322) > HDC inactive |
goncalo Member Since: 26 Apr 2013 Location: Portugal Posts: 170 |
Today i went to lunch out with the FF. After lunch when i started the engine i ear a sound and saw HDC inactive in the panel about 2 seconds no more. only that. Then everything normal.
1st Dec 2013 5:23pm |
Weejock Member Since: 30 Dec 2011 Location: UK Posts: 418 |
Probably the fairly common issue of low battery voltage especially if the RR is not used very often or for short trips.
1st Dec 2013 5:37pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6410 |
I have had this plaguing me for the last few years. can only put it down to battery not being at completely top voltage, which is obviously required for this system check on startup. It is worse in the winter when colder. Would love to turn this check off (take note GAP), only other solution is to plug the Ctek in every night p.s. HDC works fine .
1st Dec 2013 6:05pm |
Many Thanks, i'm so happy to don't be a problem but an battery issue
1st Dec 2013 7:10pm |
Thanks mike!
2nd Dec 2013 4:34pm |
JW911 Member Since: 09 Dec 2008 Location: Hampshire, UK Posts: 244 |
Standard. Battery starting to go. It'll last about a year before you start becoming the best friend of the RAC. 2021 3.0 P400 Vogue - coming!
2nd Dec 2013 9:51pm |
Mustard Member Since: 25 Jun 2013 Location: North of South Posts: 299 |
The 'bong' had been annoying me for months on & off. Weather getting colder and me using the FBH more then the 'bong' would shout at me more often so off with the old battery and on with the new Bosch..... HDC inactive 'bong'.... Gone |
2nd Dec 2013 9:58pm |
Trev18 Member Since: 23 Apr 2013 Location: North Manchester UK Posts: 267 |
I've not used the FF since Saturday (It did a trip of 200miles before going on the driveway and was sweet..)
27th Feb 2014 8:06pm |
You need to turn the steering lock to lock (Turn al the way to the left, then all the way to the right, then back to centre, this will clear all the "light faults". You need to do this whenever you disconnect the battery (or it goes flat!). .
27th Feb 2014 10:53pm |
Update..
28th Feb 2014 12:05pm |
good news on the venture cam, long may it continue .
28th Feb 2014 12:08pm |
petewild Member Since: 14 Mar 2013 Location: Croydon, Surrey Posts: 45 |
I was wondering if this might be the cause of my latest woes.
17th Mar 2014 2:43pm |
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 |
I am certainly not an expert, but given you only get an error on right hand full lock, perhaps the steering angle sensor could be the source of the error
17th Mar 2014 2:53pm |
