![]() | Home > Technical (L322) > Two issues and a question |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6373 ![]() ![]() ![]() |
I'm no expert in car electronics but if the manual says 30A and its a 15A, you need to change it, perhaps the circuit is getting overloaded?
hoppy_70 Member Since: 04 Apr 2010 Location: Peoples Republic of Mancunia! Posts: 869 ![]() ![]() ![]() |
I'm getting the buzzing as well. Sounds like it's coming from inside the right hand air vent and only happens above 80mph. Quite annoying.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35515 ![]() ![]() |
i've had this 'kind' noise on other cars and its turned out to be a dry leaf vibrating...removal of leaf and noise gone.. |
Sportex Member Since: 12 Jun 2010 Location: Up North Posts: 366 ![]() ![]() ![]() |
i have this annoying noise and constant whining which is intermiitant. Only seems to be there when MY59 Wifey in the passenger seat No body told me there would be days like these
XXXAngelXXX Member Since: 25 Mar 2007 Location: Stuttgart Posts: 4994 ![]() ![]() ![]() |
Captain Slog Member Since: 16 Jul 2010 Location: Derbyshire Posts: 49 ![]() ![]() ![]() |
Thanks for the constructive comments.
You may want to speak with MK4TTS as he just took his apart, although would need to check if his is the touchscreen version or not. Discovery 4 HSE
dantheman Member Since: 02 Feb 2009 Location: North: Lancs Posts: 477 ![]() ![]() |
Just to be sure Captain - I'd get Scotty to change the fuse and see what happens. Low cost option. |
Fox Member Since: 02 Apr 2010 Location: Essex Posts: 2313 ![]() ![]() |
I had a kind of vibrating/whoshng noise at speeds over 60mph.
M44K TS Member Since: 09 Feb 2010 Location: North East U.K. Posts: 1325 ![]() ![]() |
Who? ![]() Yeah, I had the glovebox out on mine which exposes the fusebox area, it's simple enough to remove, open the glovebox lid and remove the 6 (I think) T20 torx screws, the glovebox the slides out, then you will see the cable for the locking mechanism, remove that and there should be enough slack on the cabling for the cd changer to allow you to sit the whole glovebox on the passenger seat. You should be able to get to the rear of the fusebox as there's quite a bit of room with the glovebox out. My car doesn't have the touchscreen monitor, although I beleive removal of the monitor itself is the same for both types, which I found a link here... http://www.bmwtips.com/tipsntricks/MP3%20i...inputs.htm Other than that, I wouldn't know what's causing the screen to go off. 2006 Mercedes CLS 1991 Retro-style Mini But really finding it hard to fight the urge for a S/C... |
elpeede Member Since: 09 Mar 2010 Location: Staffordshire Posts: 713 ![]() ![]() ![]() |
Oooo that was worth looking at... old tape and elastic band required to ensure inturupion free carx mp3....
RRVSE Member Since: 18 Apr 2009 Location: Bury Posts: 597 ![]() ![]() ![]() |
I had the buzzing sound on the passenger side and mine was also the plastic trim on the outside of the 'A' pillar. Over a certain speed, it would lift due to air pressure and make a noise. The dealer simply replaced all the clips and it has been OK since. You'd expect it to be loose because it had been removed to say replace a windscreen, but I reckon it is when people try to clean the windscreen and need something to get hold of to reach over.
RRCanuck Member Since: 23 Dec 2009 Location: Ontario Posts: 172 ![]() ![]() ![]() |
to what "plastic trim" are you referring to RRVSE?? I sometimes experience a buzz as well.
The plastic trim is literally the long piece of black plastic on the outside of the car that covers the length of the 'A' pillar from roof to bonnet (hood) on the passenger side (and of course the drivers side aswell). It's held in place by poppers if I remember, but sometimes they are weak due to the reasons I mentioned.
