Home > Technical (L322) > Coolant escaping from coolant cap |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
hi matt. what number is ontop of your cap? 180 is the TD6 200 V8 [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
30th Nov 2013 9:36pm |
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 |
Hi mate, not sure what's on top but says 140 on the underside of the cap. That's the one supplied by land rover for the part number listed? Only started doing it about 2 weeks ago. Thought the tank had a slight crack so replaced the tank and cap but still does it.
30th Nov 2013 9:53pm |
Ours was losing coolant via the expansion tank bleed screw and I permanently fixed it by using plumber's Teflon PTFE tape, as covered in this link:
30th Nov 2013 10:07pm |
Mine deffo coming from the cap itself. Before I replaced the old tank and cap with a new one if I listened carefully I could hear a hissing noise from the cap which is what made me think it had some sort of split in the plastic.
30th Nov 2013 10:40pm |
This has been a problem with quite a few cars. Even caps from Duckworths have been supplied at the wrong pressure rating. Do you have your old one?
1st Dec 2013 12:43am |
yes my old cap has 140 stamped on it, never had any problems with this tank or cap leaking for the 4 years i have had the car up until now?
1st Dec 2013 1:10am |
It might be worth trying to carefully wrap some PTFE around the thread of the main cap anyway. It won't do any harm and will easily come oof if unsuccessful. It might even work! |
1st Dec 2013 7:42am |
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 |
Maybe worth getting a block test or a sniff test done to check this isn't the first symptoms of a head gasket problem 56 TDV8 Vogue SE
1st Dec 2013 8:56am |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8504 |
If it is visibly or audiably coming out of the actual cap then it sounds like the caps pressure regulator is either wrong or broken.
1st Dec 2013 11:11am |
yes i can visually hear and see water escaping from the cap when the engine is up to temp.
1st Dec 2013 1:07pm |
Yes can visually see and hear the cap leaking, yes my old cap was leaking which lead to me think and replace my old coolant tank and cap for a new one (the old one was the original tank so 10 years old) not tried the old cap on the new tank, the old cap is the same 140 rating as the new one. Matt |
1st Dec 2013 1:10pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35272 |
your 140 cap is the wrong one matt,
1st Dec 2013 1:13pm |
thats what i am thinking, only question i have on going for a higher cap rating is i have been running on a 140 cap for 4 years up until now and the new cap i have got from the land rover dealership is rated at 140 as well.
1st Dec 2013 1:31pm |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2564 |
Check that the inlet and oulet of the expansion tank aren't blocked. |
1st Dec 2013 1:58pm |
