Home > Maintenance & Mods (L322) > 2010 MY Rear Number Plate Fixing Question
carlos50
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Santorini Black
Hi all
Can someone with a 2010 MY tell me if the rear plate is screwed on by 2 x screws / bolts or if its stuck on like the earlier L322 please? I recall my previous models were stick on but the 2010 S/C I've just bought has screws through and I'm dreading taking it off fearing the f***king useless dealer I bought it from has decided to drill holes in the tailgate?
Thanks
Carl
Post #225763 28th Nov 2013 6:42pm
Martin
Site Admin
Depends on the supplying dealer, they fit the plates however they choose.
I would have thought there are inserts in the tailgate to screw the plate to though, they won't have drilled it (corrosion risk).
Post #225766 28th Nov 2013 6:47pm
5.0
Mine is stuck on.
Post #225769 28th Nov 2013 6:51pm
Mine too. There is nothing that can't be fixed with a hammer😜😜
Post #225773 28th Nov 2013 6:59pm
stuck here.. ... - .- -.
Post #225776 28th Nov 2013 7:16pm
carlos50
Thought so, can't wait to see what they have done underneath.
Anyone got any tips for preventing corrosion, rust inhibitor then painting etc but how can I get both sides without removing the inner trim?
Post #225779 28th Nov 2013 7:28pm
Martin
Site Admin
Post #225780 28th Nov 2013 7:31pm
Vogue
Regardless of model year there are receivers for screws in the tailgate - every RR I have had though has had the number plates stuck on - I always stipulate to a selling dealer absolutely no screws through my plates or i will not be taking delivery - it's a pet hate of mine - they always look Censored with screws through them
Post #225782 28th Nov 2013 7:35pm
Not too sure re insert/drilling
If they have drilled it simply remove the screws dip the threads in waxoyl put a dab on the hole and refit.
Simples Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #225783 28th Nov 2013 7:37pm
If they drill it then the scraps of metal stripped of their zinc protection will also rattle around in there and be a rust attractor.
As above, screws are tacky and so '70's when some sticky pads do a great job. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #225800 28th Nov 2013 8:52pm
carlos50
I hadn't realized there are fixing points behind the plate so fingers crossed they used those and my concern is premature
Post #225809 28th Nov 2013 9:29pm
pld118
Our RR is screwed! Very Happy
Post #225811 28th Nov 2013 9:44pm
Sparkylee
2003 Range Rover Vogue 4.4 V8 Epsom Green
We've just changed our plates and the front where screwed and rear stuck, but underneath were 2 pre made holes, sort of shaped to accept fixings, but these had just had tape covering them and then the plate was simply suck over the top
Post #225812 28th Nov 2013 10:05pm
carlos50
Just had a look and the screws are in the upper corners so not in the same place as the engineered fixing points that I have seen online. I assume that the dealer has decided to screw through the body and have purchased some rust prohibiter and a touch in pen to sort the hole then will apply some automotive hole tape before sticking a new plate over.
Cant believe somebody would think it a good idea to get a drill and start drilling the body on a car that was £80k only 3.5 years ago, makes me wonder what else said dealer gets up to Censored
Post #226127 30th Nov 2013 11:59am
