Home > Technical (L322) > V8 head gasket failure? |
RR P38 Member Since: 12 Oct 2013 Location: Sydney Posts: 215 |
Ok, a few days ago I had a "coolant low" alarm, I had been cruising quiet happily at 90km/hr. Engine running sweet, coolant had been checked that day, have had no leaks and no abnormal running or any other indications of a problem.
21st Nov 2013 5:20pm |
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 |
The RR cooling system is a pressurised system. The only time there would be no pressure in the system is when the engine is cold. The system is pressurised to stop the coolant boiling when in normal use.
21st Nov 2013 5:52pm |
Hi Andy yes correct, I accept your comments as true.
21st Nov 2013 6:03pm |
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 |
Thought all RR's used pink/orange coolant? |
21st Nov 2013 8:48pm |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
Yes wrong coolant for a start , although it is possible the system was completely flushed before the wrong coolant was put in . 2008 MY Supercharged
22nd Nov 2013 12:15am |
BIGMAMMA Member Since: 28 Oct 2012 Location: LEICESTERSHIRE Posts: 175 |
I have a BMW engine V8, 2004, but had a similar incident in February this year; Ironically checked the water level only that morning and topped up a little. Minding my own business, actually on my way to taxi Mother Dear to airport for her Winter hols. Didn't get there. The first inkling I had was when the following car (only doing around 30mph) backed right off and I saw what I thought was smoke following me. Stopped within 400 metres to find water everywhere in the engine bay. Called Mr RAC man who promptly arrived to establish header tank had a split on the corner from top to bottom. He attempted to 'plastic repair' the split and then refilled with water. She was a cow to restart - apparently typical if the head gasket's gone, and she boiled again very quickly. Diagnosis confirmed, and then left me, having arranged for proper recovery of stricken FF.
22nd Nov 2013 9:44am |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
dont panic just yet. The coolant system is a as if gets older. the system gets pressurised from the water pump to make the boiling point lower to allow the system to run hotter for emissions. mine ran at 97C but others have ran consistantly around the 107C. there are 2 stats. a mechanical and an electric/wax stat. the mechanical opens first then the electric. the electric can be opened at will if the ecu senses extra load (eg towing), full throttle to boot cooling. the coolant system works on a 50/50 mix of coolant to water. if this ratio goes above or below a set range you get the "check coolant" even if the level is correct. the only real way to check is do an sg on it.
22nd Nov 2013 6:01pm |
Thanks for all the replies.
24th Nov 2013 1:47am |
vnitos Member Since: 18 Nov 2010 Location: pretoria Posts: 390 |
similar issues with my car
6th Dec 2013 7:01am |
Im no expert on these L322......yet.
6th Dec 2013 5:28pm |
Well almost two years since my original post and all is still well with the FF.
22nd Sep 2015 12:57pm |
