Home > Maintenance & Mods (L322) > Removable Tow Bar supply / fitting - Surrey? |
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2042 |
Fit it yourself.
7th Jul 2010 11:49am |
yawlboy Member Since: 02 Mar 2010 Location: RAK Posts: 53 |
as nbunney said fit it yourself. I fitted mine in about two hours. you will need help though as the kit is heavy. |
7th Jul 2010 12:26pm |
DeltaC Member Since: 22 Mar 2010 Location: Aberdeenshire Posts: 148 |
Fitting the bar is simple DIY but the electrics need to be done someone with the diagnostic software so that they can "tell" the car that it has towbar electrics - it will then detect the presence of a trailer via the plug and disable the rear parking sensors and freeze the suspension at normal height. |
7th Jul 2010 12:53pm |
My 2002 RR did not need telling, it recognizes the fact that the Trailer module is installed and when you plug the trailer lights in it notices the change in resistance. |
7th Jul 2010 3:04pm |
VaguelyVogue Member Since: 05 Feb 2010 Location: Buckinghamshire Posts: 380 |
Indeed - I thought that all that was done by plugging in the correct wiring loom, rather than diagnostics ! |
7th Jul 2010 3:42pm |
Nigel,
7th Jul 2010 3:51pm |
No not seen that, but I did try to lower it and it said I could not, due to trailer.
7th Jul 2010 4:16pm |
Oh well.. I was told by my friendly independent garage owner that it had to be configured. I watched him do it with Autologic. Maybe you can get away with the car recognising that something is plugged into the towbar wiring and it knows the lighting load will change, that the suspension should be inhibited and the rear parking sensors should be disabled....
7th Jul 2010 4:42pm |
NickH72 Member Since: 05 Mar 2010 Location: Surrey Posts: 92 |
I would deffo like someone in the know to fit it!.. any suggestions in the SE? Leatherhead, Weybridge ish area? |
15th Jul 2010 1:55pm |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
I have the removable tow hitch and it was fitted by my dealer when I conect up the trailer the green light comes on the parking sensors at the back turn off but I still maintain full control of my suspension . 2008 MY Supercharged
15th Jul 2010 2:43pm |
Wont the dealers want about a £1k to do this? I was looking at an aftermarket, neat and tidy removable one but fitted by a known/experienced fitter |
15th Jul 2010 2:54pm |
You bet they will. I was just saying that my dealer fit tow hitch still allows control of the suspension hight . 2008 MY Supercharged
15th Jul 2010 2:59pm |
claud Member Since: 15 Apr 2009 Location: Godalming Posts: 103 |
I bought my my removable hitch on Ebay for £100 and had Guava in Godalming fit the armature, I saved a few hundred on the full installation. Make sure you get the correct armature for the year of vehicle, they changed in 2006. Contact Guava for a quote. 2018 Range Rover Autobiography
15th Jul 2010 8:57pm |
Back to this one again!
13th Oct 2010 4:31pm |
