Home > Technical (L322) > Engine removal - 4.4l v8 BMW petrol |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8508 |
Not sure a out the other questions but there are links to workshop manuals, generally known as rave in the wiki at the top of the page There is nothing that can't be fixed with a hammer😜😜
18th Nov 2013 10:39pm |
Mark_TDV8 Member Since: 18 Nov 2013 Location: West Sussex Posts: 6 |
Good point, it never occurs to me to look at rave or microcat, but that should really be my first port of call.
18th Nov 2013 10:56pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
A 4.4 engine will be expensive £3-£4K and very very hard to find as they are like hens teeth! Needs to be the same code as the engine you are removing...
18th Nov 2013 11:55pm |
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 |
Hopefully they are rare due to lasting forever Craig?
19th Nov 2013 10:24am |
Rare because not many were made and most that we're had LPG Fitted in there lives and ruined the engine... So hence their rarity... |
19th Nov 2013 10:28am |
Fair enough - although I thought LPG on the BMW M62 unit was fairly safe?
19th Nov 2013 10:29am |
LPG do's and don'ts covered here many times before, so I won't go off topic for the OP
19th Nov 2013 10:35am |
Fair enough on the LPG issue - I kept meaning to get mine done and never got round to it.
19th Nov 2013 10:55am |
Cheers for the welcome
19th Nov 2013 12:50pm |
steptoe Member Since: 23 Jul 2012 Location: london Posts: 382 |
It is. Take no notice of posts saying " i know a bloke down the pub and he said" type comments. The people that work on bmw engines and those who actually run a BMW 4.4 V8 on lpg are all very happy . |
19th Nov 2013 1:20pm |
Ragerover Member Since: 01 Feb 2011 Location: Newcastle Posts: 220 |
i drove past a breakers in Chorley lancs yesterday
19th Nov 2013 2:05pm |
paneldamage Member Since: 11 Nov 2010 Location: Preston Posts: 222 |
That will be Douglas Valley Breakers? Never used them but they were showing breaking an L322 on EBay a while back.... |
19th Nov 2013 8:04pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2032 |
if you take your head(s) off you will need to borrow, or buy a timing setup kit to retime the cams/chains. (£350) if you are dismantling, have you run the bearings? sump off first, cap off etc. might be a better idea to start by hiring a decent lit borescope to look into a bore, with piston down. -maybe a do a compression test first and look at the worst one. did it seize? can it run? these engines are fantastic, but suffer from a few other probs, ie timing guides, vanos rattles, and water system leaks. if you are buying one, ask someone who has one to listen to it. they purr lovely, but some clatter. ive not had one out. I would do lots of other work before even looking at replacing it. and replace those guides and chain. whilst at it. but that's £500 already. hope you have a garage and heater. you will be busy for the winter!
19th Nov 2013 9:03pm |
RugbyXV Member Since: 14 Feb 2013 Location: Rugby Posts: 42 |
I have one that needs an effective rebuild but the heads etc are excellent, your for £375 collected... Owning a Range Rover is the land based version of a boat...a hole in the road in which to throw regular bundles of money! |
19th Nov 2013 9:27pm |
