Home > Technical (L322) > Check engine - Bank 1 fault
Oe_tuning
Singapore 2004 Range Rover Vogue 4.4 V8 Epsom Green
Hi all,
My check engine light came on recently and I took it to the dealer. After plugging the scanner, it reads "P0171 - System too lean Bank 1".
The SA didn't know the exact root cause and wanted to rip the car apart. He said it can be fuel system leak, injector leak, fuel pressure regulator, fuel pump, O2 sensor, electrical...basically anything.
Anybody experienced the same error message?
Thanks,
Richard
Post #222868 14th Nov 2013 1:03pm
OBD II P0171 Fuel System Too Lean (Bank 1)
OBD II P0174 Fuel System Too Lean (Bank 2)
Symptoms
Check Engine Light will illuminate
In some cases, no adverse conditions may be noticed by the driver
In other cases, there may be performance problems, such as a lack of power on acceleration and some "coughing" or misfiring
The vehicle may have trouble idling, especially when warm or when sitting at a stoplight
Common Problems That Trigger the P0171 and P0174 Code
- PCM software needs to be updated
- Vacuum leaks (Intake Manifold Gaskets, vacuum hoses, PCV hoses, etc.)
- Mass Airflow Sensor (MAF)
- Plugged Fuel Filter or weak Fuel Pump
- Plugged or dirty Fuel Injectors
Common Misdiagnosis
- Oxygen Sensors
Polluting Gases Expelled
- NOX (Oxides of Nitrogen): One of the two ingredients that, when exposed to sunlight, cause smog
- HCs (Hydrocarbons): Unburned droplets of raw fuel that smell, affect breathing, and contribute to smog
The Basics
Combustion engines operate by burning an air/fuel mixture of about 14.7 to 1—14.7 parts air to 1 part fuel. When the air ratio goes below 14.7 parts, this is called a "rich" mixture. If the air rises above 14.7 parts, it is called a "lean" mixture.
Rich Mixture = Too much fuel, not enough air
Lean Mixture = Too much air, not enough fuel
To keep the engine running properly, the Engine Control Module measures the oxygen content in the exhaust with oxygen sensors and makes adjustments to the mixture by injecting more or less fuel.
The control module operates within specific parameters and under normal conditions, it will make minor adjustments to the air/fuel mixture. When these adjustments become too large, a fault code is set. When the P0171/P0174 code sets, the oxygen sensors are detecting too little oxygen in the exhaust and the control module is adding more fuel than normal to sustain the proper air/fuel mixture.
P0171/P0174 Diagnostic Theory for Shops and Technicians
When a vehicle has the fault code P0171 and or P0174, it means that computer can no longer automatically adjust the mixture between air and fuel. Code P0171 applies to Bank 1 and P0174 applies to Bank 2. Code P0174 mainly applies to V6 or V8 engines because 4-cylinder engines generally have only one bank, though there are a few exceptions. Some of the high performance 4-cylinder and straight 6-cylinder engines (such as those in BMW and Lexus) split the cylinders into groups of two or three and call them separate banks.
When the code says that the Fuel System is "too lean," it means that the computer has been adding more and more fuel, which is called Long Term Fuel Trim. Ideally, the Long Term Fuel Trim should be close to 1 to 2 percent. When a code P0171 is set, it means that the Fuel Trim is anywhere from 15 percent to as high as 35 percent compensated. When this happens, the computer knows that there is an improper condition in the control of the Fuel System.
The first step in the diagnosis of a code P0171 and/or P0174 is to look at a minimum of three ranges of the Long Term Fuel Trim numbers on a scanner. Check the idle reading—3000 RPM unloaded and 3000 RPM with at least 50 percent load. Then check the freeze frame information for the code to see which range(s) failed and what the operating conditions were.
Before we get into the main causes of P0171, let's explore why this code matters.
Why Does a P0171/P0174 Code and Running "Too Lean" Matter?
"Lean" running cars and light trucks are highly polluting vehicles. Most of the NOx pollution, which is poisonous and can cause asthma, is caused by vehicles that are running too lean. A lean running car can also misfire, which puts raw fuel (HCs) into the atmosphere. When you are behind a car or truck that smells bad and makes your eyes burn, it is misfiring and running too lean. In comparison, a "rich" running engine has no smell (CO is odorless) or you may detect a rotten egg smell, which is caused by the Catalytic Converter consuming too much sulfur, like when you are behind a big SUV at full throttle going up a long, steep hill.
P0171 is not an Oxygen Sensor problem. Before a P0171 code is possible, the computer first ran a series of tests to validate the readings from the oxygen sensors. Since the oxygen sensors passed their readiness tests and didn't set any codes, the computer then looked to the Fuel Trim adjustment. When the computer determined the air-to-fuel mixture to be too lean, it then set the P0171 code.
What Are Some Common Causes of Code P0171/P0174?
Always check to make sure that there is not a PCM software update due or available. Often, as the vehicle's engine wears, the PCM's Fuel Map software inaccurately compensates for this condition. The fuel mixture grows lean and eventually, the code sets.
A vacuum leak is very common. It could be a torn PCV hose, a torn Intake Air Boot, or even a broken seal on the dipstick (the dipstick is a part of the PCV system and if it does not seal, too much unmetered air will enter the engine). Don’t rule out a sticking/leaking EGR Valve or leaking EGR or Intake Manifold Gasket. If it is a V6 or V8 engine and the code is only on one side/bank, it could be a defective Intake Manifold Gasket or cracked/leaking manifold.
What if There Is No Vacuum Leak or Both Codes (P0171 and P0174) Set?
An "under reporting" Mass Air Flow Sensor can be a common cause of a code P0171 and P0174. Essentially, this means that the Air Flow Sensor is telling the computer that much less air is entering the engine than actually is.
Since the oxygen sensors are telling the computer that more fuel is needed, this causes confusion in the computer because the Mass Air Flow Sensor is still saying there is too little air and the Oxygen Sensor is reporting that the mixture is still too lean. The computer tried to compensate, but since resolution is impossible, it sets the code. It is important to restate that the Oxygen Sensors are accurate—the fuel mixture is too lean. In this case, the Air Flow Meter or Sensor is inaccurately reporting the real amount of air entering the engine.
How Do I Know if the Problem Is the Mass Air Flow Sensor?
There is a very effective "truth test" for any Mass Air Flow Sensor. Start the engine, let it idle, and then check the Barometric Pressure reading on the scan tool data. If the reading is about 26.5 Hg and you are close to sea level, you know that you have a defective Air Flow Meter because it is telling you that you are at about 4500 feet above sea level. (These conversion tables will help.) When the Mass Air Flow Sensor sees this Barometric reading, it adjusts its Air Density table and then "under reports" the actual amount of air entering the engine. It does this because the Barometric Pressure Sensor is actually part of the Mass Air Flow Sensor.
Sometimes the Air Flow Sensor and the sensing wire get covered with dirt, dust, or oil residue, which can also set a P0171. Cleaning the sensor might hold off problems for a while, but eventually, the MAF sensor should be replaced. Always make sure the Air Filter and its enclosure are dirt-, dust-, and oil-free. If you clean and replace the filter and its enclosure as needed, you will prevent the new MAF from failing.
Additional Causes of Code P0171/P0174
A plugged Fuel Filter or poorly functioning Fuel Pump can set the P0171 code. The computer hears (accurately) from the Oxygen Sensor that the Fuel Mixture is too lean so the computer keeps increasing the amount of fuel being delivered into the combustion chambers. But in this case, the Fuel System can’t increase the amount of fuel.
If you still can't find the problem, be sure to check and verify that fuel pressure and delivery are at spec. If fuel pressure and volume check out okay, scope the injectors and perform injector drop and/or flow tests to see if they are capable of delivering enough fuel. Dirty/contaminated gas can definitely plug injectors and trigger these lean codes." ... - .- -.
Post #222876 14th Nov 2013 1:26pm
Oe_tuning
Wow Stan...thanks
Thats a lot to digest, and a lot of possibilities.
Now I need to think where to start hahaha
Post #222879 14th Nov 2013 1:49pm
paneldamage
Start by looking at the crankcase breathers, lots of info on here about the problems of decaying hoses.... Although I would have expected you to notice a raised tick over rate, and for the defect to affect both sides of the block.
Post #222947 14th Nov 2013 5:27pm
Oe_tuning
Thanks for the replies guys....
I'll start with couple of easy things first.
Injector cleaning and recalibration, fuel filter, and vaccum leak check.
Then we'll see if there is something else triggering CEL.
Does that make sense?
Richard
Post #223439 17th Nov 2013 12:31am
jim2RRs
United States 2005 Range Rover HSE 4.4 V8 Chawton White
If it's only 1 bank reporting lean, you can safely rule out any problem with the MAF; that would trigger BOTH banks.
Some ODB tools will allow you to see the O2 sensors outputs.
They should be continuously bouncing up and down, both banks.
Fuel leak should be very easy to find.
Higher mileage vehicles will be more likely to have a cracked hose than newer vehicles.
gasket leaks can cause lean condition as air gets sucked in after the MAF. This is unmetered air, and is unexpected.
Electronic check of O2 sensors is really easy, start with that.
You can also see the fuel trims on many OBD tools, more good data points.
Make sure the valve cover bolts aren't loose; use appropriate torque wrench setting. Jim
2000 NAS HSE
2005 NAS HSE
Post #223694 18th Nov 2013 4:40pm
vnitos
South Africa 2016 Range Rover SVAutobiography 5.0 SC V8 Baltic Blue
thats one of the codes my car threw recently. in addition it had a misfire. we did the following:
- replaced spark plugs. due to the car running lean some of the plugs burnt out in 3000kms
- replaced petrol filter
- replaced air filter. Main reason for this is because my car had the 2007 S/C conversion and the previous owner, who had the conversion done, put a cone air filter in. my indie put the original filter and filter housing in thus the replacement of the air filter
- replaced ignition coil no 4
she is now running as smoothly as ever and even better so after the replacement of the viscous fan which Censored when i bought it - previous owner was told it was the auxiliary belt - this had nothing to do with the error codes
hope the above help
Post #223717 18th Nov 2013 6:39pm
chris_read
England 2009 Range Rover Vogue TDV8 Stornoway Grey
From my experience with such codes I'm with Paneldamage - PCV hoses were the cause on mine and a straightforward thing to check once you have the plastic engine cover off. My hoses were like jelly (or Jello if you aren't from this side of the Atlantic Wink )
Post #223752 18th Nov 2013 8:09pm
Oe_tuning
Appreciate all the sharing....
@Jim2RRs: useful info. Now i can rule out MAF or at least put it last on my to do list.
@vnitos: i dont have misfires, but some items you mentioned worth checking
@chris_read: agree, i'll check PCV Smile
Post #223803 18th Nov 2013 11:25pm
chris_read
Post #223977 19th Nov 2013 7:07pm
Oe_tuning
I finally got time to take the FF to my mechanic, turns out one of the injectors is bad and need replacement.
Does anyone know how to look for part number?
This is the part:
Thanks,
Richard
Post #228059 10th Dec 2013 4:08pm
dingg1
clue here
see that number above the thumb
put it into google Laughing Laughing
Post #228075 10th Dec 2013 5:46pm
Oe_tuning
Hahaha...ok, just making sure cause i found several part numbers on google.
Post #228207 10th Dec 2013 11:45pm
