Home > Technical (L322) > How long to fully charge a battery. |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3826 |
I've been thinking about my problems (with car that is ) relating to the battery. Typically I do only short journeys and as winter approaches they will often involve using the headlights, sometimes heated drivers seat and maybe the heated steering wheel - and on rare occasions the FBH .
18th Nov 2013 11:31am |
All understood BUT given that I've given the battery a bit of a knock starting the car will half an hour put it all back given that the alternator is meeting the needs of the rest of the car when its running. I know they are good compared to dynamos but the current they can generate is not infinite - is 30 minutes enough? Geoff |
18th Nov 2013 11:56am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35379 |
i think its a characteristic of the range rover that the battery goes flat for no reason..
18th Nov 2013 12:02pm |
Thanks Stan,
18th Nov 2013 12:07pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3978 |
If the battery is in good condition and is capable of starting the engine without any fuss I would have thought a 30min run with whatever you have switched on as well would be perfectly adequate. I've never had a problem with a car not keeping up with the batterys needs whilst using it 1/2 hour each day in the depths of an Edinburgh winter for 20 years where I can guarantee "everything" was on morning and night.
18th Nov 2013 12:09pm |
your theory is probably correct NDFI if you get in your range a drive off straight away but in practice its ,unlock the doors , wait for the wife to change her dress/shoes/coat yet again and meanwhile the ecus are buzzing away for about 20 minutes draining the battery..if this scenario happens many times then i can see how the battery looses its state.. ... - .- -.
18th Nov 2013 12:16pm |
Coolio thanks both,
18th Nov 2013 12:27pm |
I've just realised that I've been taking advice off David Cameron and Mr Bean Geoff |
18th Nov 2013 12:29pm |
I have to admit with the FFRR I do start the engine when I first open it to go anywhere irrespective when I subsequently leave.
18th Nov 2013 12:32pm |
@ Geoff.. ... - .- -.
18th Nov 2013 12:55pm |
drivesafe Member Since: 19 Mar 2008 Location: Gold Coast Posts: 126 |
Hi Geoff and the problem is that you will never drive long enough to fully charge a lead acid battery from an alternator.
18th Nov 2013 1:31pm |
Last winter mine was coping well with running the FBH for 20mins before a run and then a 15min drive to work with the seats and windows on as well as the lights and the radio.
18th Nov 2013 2:27pm |
Currently (no pun intended) the car is on charge using the CTEK and will be left the rest of today, all night and all tomorrow. That should allow sufficient "float" time for the battery to fully charge.
18th Nov 2013 2:48pm |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
Present :2008 TDV8 HSE
18th Nov 2013 3:03pm |
