Home > Maintenance & Mods (L322) > Roof glass
Steverr
United Kingdom 2003 Range Rover Vogue Td6 Zermatt Silver
Roof glass
Is it possible to take off the sunroof glass. It's jammed, goes up but not backwards and I think my pipes are blocked Surprised
If I take the glass out will I be able to get to the drain holes ? Thumbs Up
Post #223604 18th Nov 2013 8:35am
this has been copied from the workshop manual [rave] link is in the wiki.. probably your answer is there.
Post #223613 18th Nov 2013 9:53am
Shocked Discovery 4 HSE
Post #223678 18th Nov 2013 4:01pm
mmiata
Hungary 2012 Range Rover Vogue TDV8 Buckingham Blue
I`m just a very starter with FF and car mechanics as well. But following orders of Rave manual was so straightforward, that I could finish with the whole process within half hour.
Here it goes:
Roof Opening Panel - Roof Opening Panel Glass
Removal and Installation
Removal
1. Open the roof opening panel shield.
2. Raise the roof opening panel glass.
3. Release the upper edges of the RH and LH roof opening panel side trims.
4. Remove the RH and LH roof opening panel side trims.
Release the front of the RH and LH roof opening panel side trims and slide forwards.
5. Remove the roof opening panel glass.
Remove the 6 screws.
Installation
1. Install the roof opening panel glass.
Tighten the screws to 6 Nm (4 lb.ft).
2. Align the roof opening panel glass to the roof. For additional information, refer to: Roof Opening Panel Alignment (501-17 Roof Opening Panel, General Procedures).
3. Install the RH and LH roof opening panel side trims, starting with the rear ends.
4. Secure the upper edges of the RH and LH roof opening panel side trims 4.4 TDV8 Vogue Buckingham Blue MY12
from Hungary
Post #223921 19th Nov 2013 2:06pm
mmiata
from Hungary
Post #223926 19th Nov 2013 2:23pm
Steverr
Thumbs Up thanks
Post #224006 19th Nov 2013 10:29pm
