Home > Maintenance & Mods (L322) > Is there any way to manually lower the air suspension. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35423 |
a GAP iidtool should help ,
17th Nov 2013 9:33am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16302 |
Maybe time to fix it properly? Get the codes read/cleared etc etc |
17th Nov 2013 9:44am |
drivesafe Member Since: 19 Mar 2008 Location: Gold Coast Posts: 126 |
Thanks Stan and I’ve set them an E-mail for info on where to buy one over here. Hi C-T-C and as far as getting the codes go, the problem was never fixed under warranty ( not that I had a warranty ) so I just didn’t both but hopefully I might be able to do what the Land Rover dealer never achieved! 2007 TDV8 Lux |
17th Nov 2013 9:57am |
Granted, i cannot comment on AUS dealers but, most of my customers come to me disappointed, irritated and annoyed with UK main agents who cannot fix issues! A few being from new too
17th Nov 2013 10:05am |
Hi again C-T-C and do I need to take it to a dealer to have the codes cleared or can I take it to any generic service centre? 2007 TDV8 Lux |
17th Nov 2013 11:49am |
adigorn Member Since: 18 Mar 2010 Location: West Midlands/Birmingham Posts: 204 |
Before you go anywhere
17th Nov 2013 12:24pm |
For sure, remove the silencer.
17th Nov 2013 1:23pm |
Your silencer is blocked simple... There is a revised part from JLR with a hole drilled through it to stop it blocking up... |
17th Nov 2013 1:39pm |
We fit them as part of a service if they have never been fitted Just check yours is not full of a white powder (talcum powder like material) as that can be a sign of your compressor breaking down internally... |
17th Nov 2013 1:42pm |
Thanks C-T-C, and yep, a very fine surface covering of white powder.
17th Nov 2013 1:57pm |
Order a revised exhaust... For now (temporary fix) sit the exhaust on its thread end and you then need to drill a 2mm(ish) hole through the existing exhaust from east to west through the internal hole running north to south as you look at it... Hopefully that makes sense
17th Nov 2013 2:05pm |
Thanks again C-T-C.
17th Nov 2013 2:27pm |
As above if you can live with the sound of drilled silencer (at the end its deep under cover and spear wheel)
17th Nov 2013 2:31pm |
17th Nov 2013 2:39pm |
