Home > General > Is my FFRR trying to talk to me? |
VMPP Member Since: 12 Jul 2009 Location: Lisboa Posts: 410 |
13th Jul 2010 4:08pm |
delamo Member Since: 17 Mar 2010 Location: Beaconsfield, Bucks Posts: 1121 |
13th Jul 2010 4:30pm |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
hi, all i can think is that your phone is looking for compatable connection, now is rarotonga your blue tooth idon the car.
13th Jul 2010 7:42pm |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6370 |
The phone would not pick up the car unless the key was in the ignition and at position 2.
13th Jul 2010 8:15pm |
i can set the blue tooth id to any thing i want using navcoder. i am wondering if your cars id is in the iphone's list from a previous scan and connection and when you are serching from indoors it will still be there becouse if it was live it would connect to it... V8 facelift Range Rover Autobiography 22" wheels.
13th Jul 2010 8:34pm |
Fox Member Since: 02 Apr 2010 Location: Essex Posts: 2313 |
Could it be because after using the car you have not moved the phone very far from it?
13th Jul 2010 8:59pm |
Thanks for your responses daveo and RRUK (Edit - and Fox)
13th Jul 2010 9:09pm |
I had my honeymoon in Rarotonga, a beautiful island in the Cook Islands in the South Pacific.
13th Jul 2010 9:29pm |
You are absolutley right RRUK - That doesn't help at all
13th Jul 2010 9:37pm |
The code is 2121 try it.......
13th Jul 2010 9:54pm |
No such luck Gazellio - the 'Password' on the iPhone screen needs to be 8 characters before the JOIN button turns blue and submits the code - message comes back - Unable to join the network "RAROTONGA" - Dismiss
13th Jul 2010 10:10pm |
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2031 |
It's in the handbook I think |
13th Jul 2010 10:15pm |
ALL LAND ROVERS use the 2121 code to connect a handset via the Bluetooth Module.
14th Jul 2010 8:43am |
If its a wifi connection it is picking up then its NOT the car! Someone close by must have a wifi SSID of Rarotonga.
14th Jul 2010 8:50am |
