Home > Maintenance & Mods (L322) > 02-05 TD6 Vogue FRONT PADS GUIDE
bizzybus
United Kingdom 2005 Range Rover Vogue Td6 Zambezi Silver
Has anyone seen a guide on this site about changing front brake pads on 02-05 td6 vogue,i have been looking for days and can only see the one on the wiki but thats for the tdv8. (i take it that the tdv8s are not the same).I am not a nubie to doing brake pads but never done them on the rr and found this site invaluble for doing all the services the beast needs.
Thanks in advance (SEE WHAT HAPPENS WITH HEATED SEATS)
Post #222506 12th Nov 2013 10:12pm
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
http://www.rswsolutions.com/index.php?opti...;Itemid=78
Post #222509 12th Nov 2013 10:19pm
Pads generally are pretty easy to change, the td6 and tdv8 arr completely different front setups, the tdv 8 having brembos.
The fronts on the td6 are a 2 pot version of the rears on the tdv8 basically and will disassemble refit in the same way.
Have a look at
http://www.fullfatrr.com/forum/topic19932.html There is nothing that can't be fixed with a hammer😜😜
Post #222511 12th Nov 2013 10:22pm
bizzybus
TD6 PADS
Thanks chaps,knew you wouldnt let me down, hope it dosnt rain on sunday Very Happy (SEE WHAT HAPPENS WITH HEATED SEATS)
Post #222515 12th Nov 2013 10:29pm
You shouldnt need to remove both bolts on the caliper if just swapping the pads, take one out and the caliper will swing out of the way. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #222516 12th Nov 2013 10:32pm
bizzybus
td6 pads
Thumbs Up good tip thanks monkey (SEE WHAT HAPPENS WITH HEATED SEATS)
Post #222547 12th Nov 2013 11:51pm
If you don't manage to change them, blowing in the oposite direction you're traveling is just as effective as TD6 brakes. Laughing
Post #222549 12th Nov 2013 11:55pm
