Home > Technical (L322) > Test book
paul271
Scotland 2002 Range Rover Vogue Td6 Epsom Green
Test book
Hi guys. Might have a line on a laptop equipped with testbook. I know nothing about it!! How does it compare with the likes of All comms & IID?
Sorry for not searching much but I'm at work and typing on the sly!!
Post #222267 11th Nov 2013 10:15pm
adigorn
test book is quite powerful tool
on FF up to 2005 you can do almost anything
the problem is the gear is quite expensive and hardware not software is a problem
if you are lucky 1000GBP should get you one (maybe bit less)
Post #222274 11th Nov 2013 10:45pm
paul271
I have the chance of a laptop with testbook T4 loaded on. It has no cables with it. Should be about £100ish. Is it worth a punt?
Post #222278 11th Nov 2013 11:08pm
adigorn
Its a tricky way of selling old laptops
the t4 software can be found online
and its useless without actual gear
Sad
Post #222283 11th Nov 2013 11:11pm
paul271
That makes sense to me mate. Cheers for the heads up.
Post #222285 11th Nov 2013 11:15pm
