Home > Maintenance & Mods (L322) > TD6 AC Belt Tensioner Siezed
TerryTurbine
France 2004 Range Rover HSE Td6 Giverny Green
L322 TD6 AC Belt automatic tensioner is seized, Belt is slipping, Pulley is free to rotate but tensioner will not move seized.
Is there a tensioner replacement procedure available? Current Vehicles: 2004 RR Td6,) 97 Nissan Terrano 2 SE (Old Reliable) , 1989 Merc S 260SEL, 79 XJS V12 manual, 85 VW Sirocco GTS
Post #222139 11th Nov 2013 11:24am
Is it the one at the bottom of the engine around the oil sump area?
If so it's a common fault and an easy repair
The others are up in the area of the water pump and not so easy to access
Post #222142 11th Nov 2013 11:34am
Should be number 2 next to the blue belt in the image below
Post #222149 11th Nov 2013 11:56am
TerryTurbine
Hi Thanks for the response, The Tensioner is the bottom one, No 2
The rubber outer seal on the tensioner shaft had been split! So time to replace the whole unit I guess. Current Vehicles: 2004 RR Td6,) 97 Nissan Terrano 2 SE (Old Reliable) , 1989 Merc S 260SEL, 79 XJS V12 manual, 85 VW Sirocco GTS
Post #222160 11th Nov 2013 12:32pm
paul271
Scotland 2002 Range Rover Vogue Td6 Epsom Green
I currently have my Ac pump out and in the bench for new bearings and I think I'll replace my tensioner too provided it's not gonna cost an arm & a leg!
Post #222214 11th Nov 2013 6:33pm
TerryTurbine
Hi Thanks for the prompt response.
Is there a procedure for removing and replacing the tensioner and is possible it be carried out with the AC still in place? Current Vehicles: 2004 RR Td6,) 97 Nissan Terrano 2 SE (Old Reliable) , 1989 Merc S 260SEL, 79 XJS V12 manual, 85 VW Sirocco GTS
Post #222381 12th Nov 2013 12:47pm
