Home > Maintenance & Mods (L322) > Wing Mirror Upgrade
jimmy2508
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
Wing Mirror Upgrade
Hello Everybody. My drivers side wing mirror needs replacing. The glass has been broken, casing cracked and does not fold in anymore.
I was just wondering if anyone on here had upgraded their wing mirrors to the newer colour coded type on an early l322?
Post #221946 10th Nov 2013 9:38am
Not sure if it can be done, but CTC may know.
If you do replace with newer, I may be interested in your passenger side mirror if it all works Wink .
Post #221966 10th Nov 2013 11:47am
05-09 mirrors will fit (plug & play) to the 02-05 cars but the mirrors wont powerfold in correctly without the 05> window switch pack (different software?)
The 09 onwards mirrors wont fit the earlier cars at all Thumbs Up
Post #222007 10th Nov 2013 3:16pm
jimmy2508
Thanks for the quick response guys.
Joe- hopefully i'll manage to get them changed soon and i'll contact you if I do about the mirror.
Craig- how do I go about upgrading the window switch pack? if I manage to find a pair of mirrors
Post #222124 11th Nov 2013 10:39am
The switches you press in the top of the door panel are the switch pack... Has a built in ECU so needs to be changed to an 05> one (which looks identical but has a different part no)
Post #222129 11th Nov 2013 11:18am
Thumbs Up @ jimmy .
Post #222175 11th Nov 2013 3:58pm
andrew.aa
Italy 2004 Range Rover Westminster 4.4 V8 Java Black
as Craig said, are plun and play, (up my09) but not close properly, without the switch pack
two days ago, I fitted two brand new mirrors type my06, and work correctly ,but not powerfold function properly.
yesterday I fitted all door cards from MY10 donor and now close properly. Than could be the sw, or something else, ... I will investigate because
fron electrical wiring diagrams, must work right , but it is not so, only about folding function.
Post #222223 11th Nov 2013 8:07pm
