![]() | Home > Maintenance & Mods (L322) > Tow Bar Armature Fitting - Pics |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
Good write up there |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35644 ![]() ![]() |
nice job Paul, wiki'fied.. |
TugRR Member Since: 11 Jan 2011 Location: Bakewell Posts: 1200 ![]() ![]() |
^ Roger that !
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
Not the hardest of jobs but it's pigging heavy work!!! |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3895 ![]() ![]() ![]() |
No pictures in the Wiki as far as I can see |
you're correct geoff, it seems back in 2013 Paul used an external image provider and these images have been deleted?. ... - .- -.
Mmmm ? . . . . Where did they go - I uploaded them from my pc as I always do ?
Well actually I finished the job this afternoon - my advice is if someone offers to professionally fit everything for £150 let them do it. It's a simple enough job and everything you need to do is obvious but some of the things that need doing are a real PITA. Still I am now basking in the warm glow of satisfaction of a job successfully completed and am a bit knackered good job the brother in law turned up when help with lifting was needed |
you did bolt it on properly geoff?
All bolts in place and torqued up, thanks for asking. I Try not to make the same mistake twice |
I held back putting on the plastic bumper as it's much easier to give it a good clean and wax on the bench which I have done (all those annoying little tar spots). I still haven't put it back on as I am waiting for the electrics from PFJones, none in stock but half the price of JLR should be here today or Monday.
Have you got new pictures then Geoff so they can be added to the wiki?
Sorry no pictures, I didn't even mean to make a start so no camera. It's actually so simple there's none needed its a simple DIY job. I think my biggest worry was getting the sides of the plastic bumper out of the lugs without breaking anything, even that was simple after I figured it out. On a 2010 the rear metal bumper is pretty light however when added to the armature combined its a heavy |
