Home > Technical (L322) > Time for FBH- what do I need to buy then?
Page 4 of 4 <1234
mjdronfield
Here's my old thread ;
http://www.fullfatrr.com/forum/topic14880.html?highlight=pre+heat
Which I now think has the wrong conclusion if I'm honest.
Having gone through another winter, its definately when the fbh is on to aid faster water warm up on the diesel......pretty sure........ 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #212276 25th Sep 2013 6:57pm
SteveMFr
Site Sponsor
Actually, it is not 100% clear but I am 99% sure it is an additional warning that the glow plugs are needed (which they barely are in warmer temps - you can start the M57 almost like a petrol motor). 2 main reasons:
- the message only appears prior to engine start. For the FBH to produce any heat you have to go through the starting sequence which lasts ~1 minute and then it still takes the FBH several additional minutes to produce any real heat. The only way that becomes Pre- (vs. Aux-) Heat is if you have the Park-Heat function activated and allow the FBH to operate for a while before starting the engine.
- the real give-away, tho, is the equivalent German cluster message: Vorglühen. Translated literally this means Pre-Glowing. And if the FBH starts glowing, you have a problem. Laughing
I wonder what they mean by 'deactivating' the function, tho (in your other quoted thread). If they do mean 'just start the piece if you don't want to wait' then deactivate is a strange term to use. I am relatively sure it is not in the CCF. Maybe a poor translation as this probably came from BMW's engineering dept? Too much O-fest beer prior to sitting down at the PC by the owners manual guys?
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #212383 26th Sep 2013 8:31am
steve9bug
United Kingdom 2004 Range Rover Vogue Td6 Zambezi Silver
Just put the timer on for what I think is the heater. The on the screen for heating is set to come on tomorrow see if it works.
Its left an orange light on the screen button so think its on standby to work.
There was two timer settings but just set the No.1 setting.
If this works can I get a hand remote to work it or will I need to check somewhere to see if the receiver is fitted.
54 REG TD6 Vogue WITH TOUCHSCREEN
Post #220720 4th Nov 2013 6:25pm
If it works there is a good chance a fob would work once paired up.
But to be 100% sure you need to know if you had remote park heating specced when the car was made.
This can be done by locking for the webasto remote unit which I think is in the passenger side rear boot area.
Or on a copy of the build sheet Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #220725 4th Nov 2013 6:45pm
steve9bug
Just looked on build sheet says
Park heating with remote, might contact the last owner see if he has a remote its only had one owner might be worth a go if not will but one.
How can I pair it with the car if I do
Post #220727 4th Nov 2013 6:52pm
Page 4 of 4 <1234
