Home > Camping, Caravanning and Holidays > What mirrors do you use
Andy
I've just bought some grand aeros off eBay. I was about to ask if they fit the FFRR before bidding. What are they like on the move?
Post #220512 3rd Nov 2013 6:44pm
mzplcg
Not the best TBH. They vibrate quite a lot, so much so that I replaced mine with Milenco Aero-2's The upside of doing that is that I ended up bending the arms a bit to match the curve of the FF mirrors and I use 3 clamps each side now. Even like that the Grands vibrate but the Aeros are rock solid.
Post #220517 3rd Nov 2013 6:59pm
IanV8
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
I find the Grand Aeros rock solid.
Mounted on top of the mirrors there is no need to bend the arms as the brackets swivel.
The stick on ones used to drop off on bumpy roads.
Ian
Post #220682 4th Nov 2013 2:43pm
n1cktdv8
I have now added colour coded mirror tops so have my grand aero's mounted on the bottom, no amendments to the mirrors or arms - great mirrors and rock solid Thumbs Up Is this where I put the car details and a bit about myself ?........
Post #220695 4th Nov 2013 3:49pm
Andy
I can't mount mine on the bottom as the body is too thick for the clamps.
Post #221574 8th Nov 2013 8:46am
http://www.ebay.co.uk/itm/ROCK-STEADY-TOWI...1284007113
i use these, when i got then they came with two sizes of clips, the larger of which is spot on for the FF.
The are good and though there is a small amount of vibration you can still see very well indeed.
And they are cheap! There is nothing that can't be fixed with a hammer😜😜
Post #221801 9th Nov 2013 9:47am
