Home > In Car Electronics (L322) > Mirror not dropping in reverse?
stuboy00
Scotland 2006 Range Rover Vogue SE Td6 Java Black
When I select reverse my passenger mirror isn't dropping now the camera comes on and the sensors also all work it's just the mirror isn't dropping? Any ideas? F**K IT you only live once
Post #220363 2nd Nov 2013 5:00pm
The switch for adjusting your wing mirrors may be set the wrong way - can't remember which way round it is, drivers or passengers - but one way drops the mirror and the other leaves it up
Post #220369 2nd Nov 2013 5:22pm
stuboy00
Ah many thanks just found out her majesty was out in the car pressing buttons lol F**K IT you only live once
Post #220371 2nd Nov 2013 5:25pm
Dolphinboy
United Kingdom 2015 Range Rover Autobiography SDV8 Baltic Blue
square button over to the left (passenger) side should activate it. If it doesn't, it could be it is jammed or caught on something inside the mirror housing. Mine was a bit iffy at first but manipulated it a bit and now works fine.
Post #220372 2nd Nov 2013 5:26pm
Sparkylee
2003 Range Rover Vogue 4.4 V8 Epsom Green
Thanks for that Bow down
It bugs us because our drive is like Mount Everest and when it dips down you can't see anything
Was waiting for IID tool to arrive to see if I could switch it off Embarassed
Just tried while waiting for SWMBO to come out of sainsburys Thumbs Up
Post #220377 2nd Nov 2013 6:08pm
Post #220382 2nd Nov 2013 6:34pm
steve9bug
United Kingdom 2004 Range Rover Vogue Td6 Zambezi Silver
Never looked at mine but it now works Laughing moved the button over Wink
Post #220485 3rd Nov 2013 3:46pm
Laughing All my spelling errorz are belong to me!
2023 FFRR L460
2021 AM new Vantage
Post #220487 3rd Nov 2013 3:47pm
SATVC
United Kingdom 2004 Range Rover Vogue Td6 Java Black
When I put mine in reverse the passenger mirror just goes mad! Left right up down??
How do you actually set it to drop where you want?
Post #220566 3rd Nov 2013 9:02pm
Oe_tuning
Singapore 2004 Range Rover Vogue 4.4 V8 Epsom Green
Hi SATVC,
I'm a recent owner so not sure if i did it the correct way or just pure luck haha
My way:
I set the car to reverse, when the mirror dips then i adjust to my liking, then I set the memory seat.
After that it seems to dip to the same position.
Cheers!
Post #220828 5th Nov 2013 6:10am
SATVC
That's great, I'll give it a go. Thankyou
Post #220834 5th Nov 2013 7:40am
stormindes
United Kingdom 2003 Range Rover Vogue Td6 Oslo Blue
Oe_tuning wrote:
Hi SATVC,
My way:
Cheers!
Think that the rave manual says something along these lines (and stand to be corrected- but have read it somewhere) but I gave in after a few attempts and just accept where it stops. However some days it does have a bit of a fit and can't make up it's mind where it wants to go, i just put this down to a possible connection issue and I've added it to my lengthy list of things to do Wink
door card square button does switch off this option as stated earlier in this thread tho and is more often than not the cure to the 'WTF is wrong with it now Big Cry ' moments of dispare Yes I was there but I wasn't directly responsible for that particular part because I was way over there in the corner with my back turned and anyway I wasn't even supposed to be here today
Post #221303 6th Nov 2013 9:36pm
