Home > Technical (L322) > More Gearbox/car woes |
Nappler Member Since: 09 Jun 2010 Location: Surrey Posts: 158 |
Tried removing the fuses for the transmission to reset the transmission ECU, when I put them back in I got, Air Suspension inactive, the DSC and ABS lights were on too, hopefully these will reset themselves. |
10th Jul 2010 11:56am |
You need to turn the steering wheel left to right full lock to reset the steering angle sensor if you've been pulling fuses.
10th Jul 2010 12:08pm |
Thanks, did the steering wheel left to right and got rid of air suspension.DSC,ABS etc lights being on.
10th Jul 2010 2:22pm |
DeltaC Member Since: 22 Mar 2010 Location: Aberdeenshire Posts: 148 |
Sounds unlucky... If the belt has gone, your power steering will stop too and the steering will get very stiff. Water temp guage would hit the roof in about 30 seconds...
10th Jul 2010 2:25pm |
I'm just going to get it to a garage, Radiator change and gearbox oil change isn't too bad labour wise and I will source the parts myself, my main worry is the alternator, but does seem odd that it would just stop working instantly, however after a google search and some reading it seems this has happened before with other people so I will make sure first, then time to bite the bullet and get the £400 ish alternator. |
10th Jul 2010 3:17pm |
Just an update, it's awaiting repair at the moment, their going to fit new rad and change gearbox oil, and new alternator, car had enough power in the battery to get down there but I suspect it will need a charge.
13th Jul 2010 3:38pm |
