Home > Maintenance & Mods (L322) > Lazy starter |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35217 |
try a drop test on the battery ..although its reading over 12 volts this might go down dramatically when a load is put on it. ... - .- -.
30th Oct 2013 9:26am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3969 |
I sometimes wonder if as these cars get older the engine earth strap connections get corroded and add to starting problems as described. I also wonder if it adds to electrical gremlins related to the engine and transmission.
30th Oct 2013 9:36am |
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 |
It's all to easy to point at the battery.....like I did !
30th Oct 2013 10:25am |
Steverr Member Since: 27 Oct 2013 Location: Bristol Posts: 191 |
Thanks for the quick replies. Haven't done a drop test yet but tested it first thing this morning without having started it first and read 11.95. Did a work on it, tailgate open and doors for a couple of hours and down to 11.85, but still haven't started it yet... I will try the drop and see what happens.... |
30th Oct 2013 2:04pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8488 |
Might find it very sluggish to start if the doors have been open for a few hours. It tends to have a fairly detrimental effect...... There is nothing that can't be fixed with a hammer😜😜
30th Oct 2013 2:38pm |
Ok did the drop test. Was at 11.7 to start then dropped to 9.3 and didn't start , flat as a turd.... Trickle charged it for 1 hour, now back to 12.4... Tried to start but nothing ..... I think it's !!! Gonna take it off and give it a good charge to see if it will take it but I think not |
30th Oct 2013 4:49pm |
batterys are made of 6 x two volt cells so it sounds like one cell has gone [or is going].. ... - .- -.
30th Oct 2013 5:46pm |
Sounds like a new un then don't it
30th Oct 2013 7:31pm |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 |
Steve
30th Oct 2013 11:28pm |
Sorted, i hope.... new battery done. Put it in and bingo, first time... |
1st Nov 2013 6:47pm |
