Home > Technical (L322) > Odd sunroof action: Bounces back on closing
Go to close the sunroof with the one click forward, it goes all the way then retracts back at the last second, almost as if it came across an obstruction.
Seems to have periodically, not all the time. One way to close the roof is to press for the tilt open, then go for full close.
Anyone else had the same? Discovery 4 HSE
Post #21973 9th Jul 2010 4:31pm
daveo
hi, had it on a bmw i had, it just needed some silicon spray, it was very stiff and when it was almost closed it would open again, the last inch was so stiff it must of thought some one had a hand or some thing there so would open again for safty, after the spray it was 100% V8 facelift Range Rover Autobiography 22" wheels.
Post #21982 9th Jul 2010 6:19pm
hoppy_70
England 2018 Range Rover Autobiography 2.0 PHEV Loire Blue
Mine was doing this all the time. They sorted it under warranty but unfortunately didn't tell me what they did! Gave the usual 'weve "reset" the sunroof'
They didnt use any parts though so it probably is something simple like lubricant...
Post #21985 9th Jul 2010 7:01pm
Polux
2005 Range Rover Autobiography 4.4 V8 Monte Carlo Blue
i had this 3 times and every time it happened i had opened the sunroof a few days previous and stupidly put the washes on while open i think it got wet somewhere. was fine when dried out.
Post #22189 12th Jul 2010 9:25pm
Macdaddy
2003 Range Rover Autobiography 4.4 V8 Java Black
I had this also,
Its basically when the sunroof thinks somethings in the way of it closing. A good clean and WD40 or as suggested silicone spray solved mine. TDV8 HST Sport **Current**
4.4 V8 Autobiography and 22" wheels **Gone**
Post #22251 13th Jul 2010 8:53pm
