![]() | Home > LPG > Won't start on petrol |
Mph28mph Member Since: 16 Jun 2013 Location: Wigan Posts: 112 ![]() ![]() ![]() |
Hi I have a 2002 on lpg and the switch won't turn to petrol from gas.
SoggyBottoms Member Since: 05 May 2012 Location: Northants. Posts: 457 ![]() ![]() ![]() |
sounds like you need a pro to have a look really.
Only had it six weeks.
a normal garage won't help, you need an LPG specialist.
LPG Conversions
place looks professional, good reviews. |
D16XEY Member Since: 29 Oct 2013 Location: Broughty Ferry Posts: 20 ![]() ![]() ![]() |
I had a similar problem but it turned out to be the fuel pump in the tank had failed, |
Glynn Member Since: 20 Sep 2013 Location: Lancs Posts: 64 ![]() ![]() ![]() |
http://www.lpgconverter.co.uk/item.php?id=193&dir=31
paneldamage Member Since: 11 Nov 2010 Location: Preston Posts: 222 ![]() ![]() |
They don't like running out of petrol as the pump will continue to run dry and eventually overheat, at least that's what happened in my Classic a few years back |
