Home > Maintenance & Mods (L322) > Question after 2006 facelift conversion
Page 3 of 3 <123
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
Thanks Dave - I plan to have a good look around today to see if I can work it out. I may well start by using the old pump to see if it all works and them work out if I can swap out for the new pump.
I tried with the jumper but didn't seem to work but nor did the old wiper motors back in place! Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #182665 13th Apr 2013 8:23am
comports
All fixed and I need shooting please.....
Didn't realise that despite my efforts it was never going to work after I blew the fuse in the glove box. IT must have gone when I first jumped the connection in the wiper plug to the wrong wires. Changed that for a good one and all is fine.
Thanks all for your input as always. Will post pictures once it dries out..
Thumbs Up Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #182761 13th Apr 2013 4:00pm
daveo
nice one, and just for the record what wires did you bridge.... Thumbs Up V8 facelift Range Rover Autobiography 22" wheels.
Post #182771 13th Apr 2013 4:52pm
comports
Hi Mate,
Johnny Dangerous post in the thread was black with yellow stripe to the black with brown stripe. Its the two outer most wires on the 4 way plug.
I then fedd the old pump to the new pump water pipes (leaving the old pump in line) and then wired up to the new pump. Still doesn't seem to wash every 6th squirt but each time you turn the car on and wash the window it does. Haven't tried very hard yet but it works..!
Thanks for you help Dave!
Ash Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #182773 13th Apr 2013 5:09pm
daveo
so did you add an extra pump Question V8 facelift Range Rover Autobiography 22" wheels.
Post #182835 14th Apr 2013 9:25am
comports
Hi Dave,
I added the new pump (high power pump) and this is the pump that has the electrical connection and activated on use. I had to leave the old pump in place as the new and one is not the same fittings and couldn't connect it direct to the washer bottle and thus replace the old pump.
So the set up was old pump connected to the bottle and then water flow through into the new pump where the new pump took the power to feed the jets. The old pump is not powered in any way so just inline from a water point of view.
works great but gets the bonnet wet from the power. May have to adjust the jets down a bit more. Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #182837 14th Apr 2013 9:47am
MrP
England 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
Glad I found this thread - I'm just finishing off my 2006 conversion and have replaced the washer bottle and pumps with the new ones including the high pressure one - transferred over the connectors. Windscreen wash is fine - rear wash is fine but nothing on the headlamps. I will go and jump the wires mentioned a few posts back and see what happens. "On first name terms with my local Dealer......now."
'61 Plate 5.0SC Autobiography - in Black ——— Gone
'53 plate 4.4V8 Vogue Bonatti Grey inside and out. ----- Gone
Post #219512 29th Oct 2013 2:46pm
MrP
Ok so I have followed the above directions and have bridged the outer two wires on the four way plug. First time you start the car and wash the windscreen I see a blast from the headlight washers Thumbs Up however after that I don't seem to get them to come back on again unless I restart.
Has anyone got this fully working on every 6th wipe etc? "On first name terms with my local Dealer......now."
Post #219546 29th Oct 2013 6:11pm
comports
Others can chip in here but I think I asked the exact same question. there is also a time delay on this so it will only work again after 3 (??) minutes or something like that and again only on the sixth press?
I was worried it would;t pass the MOT but it sailed through (on that at least) Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #219559 29th Oct 2013 7:42pm
MrP
That's great to hear - many thanks for the info. "On first name terms with my local Dealer......now."
Post #219562 29th Oct 2013 7:57pm
Page 3 of 3 <123
