![]() | Home > My Range Rover > 2006MY SC - Spec |
SKOT Member Since: 24 Oct 2012 Location: Milton Keynes Posts: 792 ![]() ![]() ![]() |
Vehicle built August 2005
Yes, Dan did that and it's given me pages of extras but nowhere does it actually make reference to Vogue SE...... 2006 4.2 SC
Annoying. MY 2010 5.0 SC Galway green and sand interior!!
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35487 ![]() ![]() |
if it helps ,this is what i have on my AB build sheet so you can compare.
Thanks both.
i suspect that the trim level entry in the wiki might not be that accurate.. ... - .- -.
Ah I see..............Well maybe it is an AB afterall and the AB badge on the boot is correct?
as in my pm Steve i reckon the 'unbadged autobiography' bit is the answer.. ... - .- -.
2005 mdl was just a Supercharged Vogue SE , ====================================
Thanks Joker - It's a 2005 registered but 2006MY. If that makes a difference? 2006 4.2 SC
Same as the one I previously had back in 2005 ....... 2005 but a 2006 mdl Supercharged Vogue SE was the highest spec at that time as there wasn't a AB SC then , the AB SC came out in 2007 / 08 mdl ====================================
CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528 ![]() ![]() |
Mine was registered in 2005 as well - 2006MY Supercharged, also listed as 'unbadged autobiography' - mine has the two tone leather which I beleive is the autobiography bit.....hope this helps Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather..... |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3759 ![]() ![]() |
Polux Member Since: 02 Jun 2009 Location: UK Posts: 242 ![]() ![]() |
check you have the autobiog plate under the bonnet at the front, should have your AB registered number
